Question about Polaroid TLA-01911C TV
Black square on screen
Black rectangle on screen. It appears on fox news channel only, not commercials. It's not on any other channel.
  • 1 more comment
  • Anonymous Jan 09, 2009
    I pressed the freeze button and the box did go away, but after about a minute it came back again. HELP!!!
  • Anonymous Mar 04, 2009
    black square....on screen, ch.4 & 9 (cable) I think it has something to do with volume, when it's muted the black box goes away
  • cashed Mar 04, 2009
    black square pops up ch. 4 & 9, I think it has to do with volume, when it's muted, back square goes away Polaroid TV
I hit the freeze button and it came offf
Posted on Sep 23, 2008
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Black rectangle appearing in lower half of screen on 32" Aquos
did you turn off the close caption settings in the set up menu.
Sep 15, 2012 | Televison & Video
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Have a black-out square appear on some channels especially FOX
GO INTO THE MENU AND TURN THE TEXT OFF. THIS IS ASSOCIATED WITH THE CLOSED CAPTION. CC1, CC2, CC3, CC4, T1, T2, T3, T4, OFF
Jan 22, 2009 | Broksonic TV
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Black square on tv screen
Turn off your closed caption...
Bill
Mar 20, 2008 | Televison & Video
Black Box at bottom of screen
The text mode has been activated either thru your cable/satelite box or your tv's. It is activated because the closed caption portion. If you think its because of your channel providers call them for the process to deactivate it . If it's your tvs check your menu's to make sure the closed caption portions are turned off. Good luck
Feb 22, 2008 | Symphonic SC519DD 19 in. TV/DVD Combo
Usually that is a part of the closed caption settings. If it is set to either T1 or T2 that box will appear ....
Dec 17, 2007 | Televison & Video
Black on lower half of screen
This type of problems and some OSD problems are occurs due to microprocessor over modulation. One option is there. That is if you have any child lock or keypad lock or frontpanel lock. First locked the system. Now check your problem arise. If it is not OK. Otherwise try to find nearby any radio frequency cable across in your tv. keep away that cablewire also. your problem solved. Even you get Call your nearst service provider..
Aug 23, 2007 | JVC AV32F577 32" TV
Polaroid TLA-01911C TV Logo
110 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
