Question about Panasonic CT-32HX40 32" TV
Unable to view fullscreen in hdtv
We connected a HDTV set top box and are bothered with the black bars on the top and bottom. How can we view the fullscreen on our Panasonic CT-36HX40B 36" TV?
  • Anonymous Feb 04, 2009
    There must be a way to switch from "letterbox" to "full screen" on this TV. I called Panasonic and the guy asked me if it was attached to a cable box - it is. He told me that it was a setting on the cable box that needed to be adjusted. Can't find it..
    Scholar:
  • 188 Answers
That is the way HDTV is viewed on many screens as a wide fromat. So you will get top and bottom non-viewable areas. It is the width that gives the full imagery for that format. To have the screen filled you would get a standard 4:3 format like standard TV. HD is a 16:9 format so it is much wider.
Posted on Sep 22, 2008
How can I get full screen with my toshiba 40"" HDTV
Hello
To remove the black bars from the top and bottom, press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
OK.
Apr 23, 2011 | Toshiba 40RV525R 40 in. HDTV
Black bars on top and sides of programs
This comes down to your settings on your freeview/sky box. or the settings on the TV. Check that the screen is set to something like 16:9 or wide and not auto or 4:3. This goes for the freeview/sky settings too.
There isn't a fault with your screen it comes down to transmissions
May 31, 2010 | LG 42LG50 42 in. LCD HDTV
Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
Jan 21, 2010 | Vizio VX37L Television
I am getting a blue screen that says mode not supported when I try to view HD channels
This usually indicates that you are trying to watch a screen in a higher resolution than the Tv will actually handle
Aug 17, 2009 | Televison & Video
1- I have a Panasonic TV (PT-53TW54)that has a "digital scan rate of 1080i,540P". I'm not sure if that means it has a digital tuner. Do I need a digital converter for this unit? 2- I'm using a...
1. Do I need any additional equipment to watch HDTV broadcasts on my HDTV-compatible TV?
In order to view over-the-air (OTA) HDTV broadcasts, you need to be within the reception area of a TV station broadcasting HDTV signals. Some TVs may require a set-top HDTV tuner and an external antenna to receive the broadcasts. Your cable or satellite provider may also offer HDTV channels as a part of their service, eliminating the need for a separate tuner. Please contact your local service provider to find out what kind of HDTV services they may offer.
2. What is CableCARD and how does it work?
HDTVs with CableCARD slots can accept a small card from your cable provider that allows you to receive standard definition and high definition digital broadcasts without a bulky set-top cable box. Please call your cable company to find out if they offer this service in your area.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif3. What is HDMI? Is it compatible with DVI?
HDMI, which stands for "High-Definition Multimedia Interface", is the consumer electronic industry's first connection capable of transmitting uncompressed digital audio/video signals. Components featuring HDMI can transmit both digital audio and video over one convenient cable, replacing the tangled mess that resides behind many home theater components. HDMI also offers improved quality over traditional analog connections thanks to all-digital transmission. Digital sources like DVDs and HDTV programming can now be transferred digitally from source to display without analog conversions that can degrade the original signal.
Unlike the HDMI interface, DVI only handles digital video. Through the use of an adapter, a DVI device can be connected to an HDMI device, but only video content can be transmitted. The audio signal would have to be transmitted through other methods such as analog RCA outputs or an optical digital output.
4. What's the difference between 720p and 1080i HDTV broadcasts? Does my CRT projection HDTV support both?
HDTV signals can be broadcast in either 720p and 1080i. It's up to the broadcaster which signal format to use, and both have their benefits. Our CRT projection HDTVs display 1080i signals in their native format. For 720p broadcasts, you can use the settings on your HDTV set-top tuner, cable box, or satellite tuner to convert a 720p signal into a 1080i signal that your TV can display.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif5. Why do I still see black bars on my widescreen TV when viewing certain widescreen DVDs and HDTV broadcasts?
Your widescreen TV has an aspect ratio of 16:9 (1.78:1), which is the aspect ratio of HDTV. However, movies are filmed at several different aspect ratios, including 2.35:1. Also referred to as "scope", 2.35:1 is a very panoramic aspect ratio that provides a wide field of view in the theater. Scope is much wider than your widescreen TV, so it still requires the use of letterboxing ("black bars") to fit the entire image on screen. Some TVs and DVD players have a zoom function that allows you to blow up the image so it fills the screen, but the sides of the image must be cropped in order to do so.
6. What will 4:3 broadcasts and DVDs look like on a widescreen TV?
There are multiple settings for adjusting the appearance of 4:3 material on Panasonic widescreen TVs. It can be viewed with black bars on the sides, preserving the way it was originally intended to be viewed. Some viewers find the black bars distracting, so they might prefer one of the stretch modes that lets you fill the entire TV screen with the image. One such mode is the JUST (justify) mode, which stretches only the outer portion of the picture while leaving the center untouched.
Oct 21, 2008 | Panasonic Televison & Video
Sound issues Samsung series 6
The speakers that come with built into the units are very limited at best. Better than the old 4" speaker that came in TV sets from the old days, but not by much. Ask if you are not expecting more out of the output than is reasonable.
I would offer that the true design intent is to hook the HDTV into a home surround system, a home system is optimized for and designed for your listening pleasure. I'm guessing that your HDTV is an LCD with a sound bar at the bottom, if so it is for general use and not intended for critical listening.
I have a 61" Series 7 DLP and even with larger built in speakers, the difference is night and day between my surround sound system and the HDTV stand output.
john
Aug 14, 2008 | Audio Players & Recorders
TV PICTURE ISSUE
sir thers no problem with your unit its the user's fault
Jun 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture problem
I have an older Mitsibutishi 52" HD 1080. I recently upgraded my cable box to DirecTV HDTV. When I change to format to view in 1080 the TV goes from full screen to what seems to be wide screen with a black bar on the top and bottom. If I change the format to 480p I get a full screen; but the picture has a "redish tint" over it as if looking through sunglasses...I tried everything in my TV manual even call the cable company. Any suggestions?
Jun 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Viewing HDTV on a Sony 53" KP-53HS30
This TV is a projector - not a plasma. I can't see how you would get "burn in" on this set. It should handle an HD picture fine.
Jan 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Panasonic CT-32HX40 32" TV Logo
363 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
