Question about Epson Stylus CX8400 Series
Epson stylus cx8400 will not print black, how do I fix
  • nonnie Oct 17, 2011
    I do not understand your answer. I have new black cartridge in the printer. It used to print just fine, now it only prints any color but black. If I change the document text to blue, it will print.
  • nonnie Oct 19, 2011
    It does not print black in the test page
    Guru:
  • 1,082 Answers
From the Epson web site:
Q:
Can the printer still print if an ink cartridge is expended or not installed? A: No. The printer will not operate if any cartridge is expended or removed. It's best to always have extra cartridges on hand.
I do this for fun not $$$.
Jim
Posted on Oct 16, 2011
  • Jim Winger Oct 19, 2011
    Hmm, I assume you have installed it correctly and removed the tape. Have you run the test page? Does it show black printing?
    Remove the black, double check that the ink nozzel is not blocked then re install and re-try the print test. Does the print manage show the black cartridge? Does it show full?
SOURCE:
Epson cx8400 stylus will not print from pc.it will copy and scan.dont know what happened
if you have the cd-rom
remove the program,reboot pc.
install the program back and wait whit connecting the cables,
untill the program ask for it.
Feb 02, 2014 | Epson Stylus CX8400 Series
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
My printer wont print black and white only
My Epson Stylus cx8400 uses ink so fast. I would like to turn this into a black and white printer only. The problem is, I am out of one of the color ink cartridges and it won't let me proceed until I replace it. Is there a way, in the mode it's in now, to get this to print with the black and white only? I am nearly out of ink on all color cartridges now and do not want to purchase more at the high cost they are.
Thank you!
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
All four new ink out in printer still wont print black ink epson stylus cx8400
Your Printhead for the black cartridge is blocked. You might need to have the printhead replaced.
Aug 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Cannot Print from on Epson CX8400 from Mac OS X Leopard
I could only get my CX8400 to work with Leopard once I manually selected the driver located at /Library/Printers/PPDs/Contents/Resources/EPSON Stylus CX8400.gz
I think that may have appeared after installing a driver downloaded off the web, but I didn't track my steps carefully enough to be certain. I used http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342&prodoid=63069506&infoType=Downloads&platform=Macintosh
I know this is a bit jumbled, but hopefully it helps.
Jul 08, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
Dec 21, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson CX8400 Blank Pages
i was having the same problem and just got off of the phone with tech support who fixed the problem for me,
go into system preferences
print and fax
there you should see the printer cx8400.
remove the printer by clicking on the - sign.
then re add the printer, by clicking the +
the computer will search for the drivers and install them.
that should have you printing like a champ.
hope this helps.
WW
Jul 22, 2008 | Epson CX8400 All-In-One InkJet Printer
Computers & Internet Logo
400 people viewed this question
Top Epson Computers & Internet Experts
Philippos...
Level 1 Expert
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
