Question about Kenmore Refrigerators
Kenmore refrigerator not cooling
The compressor is hot, no ice blockage, both fans work (interior and exterior)..........but the freezer and refrigerator are not cooling.
I think you are wrong. Had the same problem. Purchased it at Sears 6 yrs. ago. What a mistake, not very helpful, condascending people. Call Centre personnel go by rote. Had to wait 5 days for repairman, cancelled Sears and went to a small private outfit. It wasn't the compressor at all. It was the condenser and guess what there was no dirt on the condenser. Total bill for part and labor $129.00 Can. BE CAREFUL WHO U CALL FOR SERVICE!!
Posted on Aug 04, 2010
  • 943 Answers
Hi thanks for the question if both fans are working no ice build up & no dirt on condencer by the compressor sorry but you need a new compressor thanks the appliance doc
Posted on Sep 22, 2008
Stopped cooling
My refrgerator a Kenmore, model 106-71182101, with ice maker stopped cooling and freezing.I vacuumed the condenser coils, and
fan in the rear bottom, along with any other debris. I unplugged the frig because the compressor was very HOT!.Question? Could the compressor have a Locked-Rotor? If so what can I do to loosen it.
Apr 08, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 795.75212402 My ice maker drips water in ice tray and makes one big friggen ice cube. Removed inspection plate from back,cleaned everything(quite dusty) and noticed the cooling fan does not kick...
The fan you are talking only come on when the compressor is on. If the compressor is on and the fan is not. Feel the compressor to make sure it is not really hot. BE CAREFUL is can be extremely hot. If is you may have a big problem. The compressor could have whats called warped the internal composent do to heat. It is suppose to be warm to a little hot. If the compressor is not that hot and comp is on than replace fan.
As far as the ice maker drippind. The silinoid in the inlet valve may not be closing all the way. Replace inlet.
Jul 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Why does my freezer work but my refrigerator doesn't?
my westinghouse fridge
the freezer is working but not the fridge
Feb 05, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Not cooling
If you still have this problem I would like for you to check to see if the fan below the refrigerator is blowing. This fan is called the condenser fan and is located beside the compressor in bottom rear under the refrigerator. If it is not running It may have a piece of paper or mouse or something lodged in the blade or it may just have bad motor bearings. If you use an exterior fan to blow air under the refrigerator it will cool again till you can replace the bad condenser fan motor.
supertechks
Aug 14, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
366 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
