Question about Xtant A3001 Car Audio Amplifier
How do you make two dvc subs run at one ohm and put them to a 2 ohm mono block
I wanted a diagram of how to wire up to 3000 wat fusion fcw they are both dvc subs and I want to run them at one ohm on a two ohm mono block how do I wire this up as I dont want to blow any thing
    Problem Solver:
  • 12 Answers
Make sure your amp is one ohm stable. If you wire the subs at one ohm and the amp is not a one ohm stable you run the risk of blowing the amp if not both the amp and the subs
Posted on Oct 23, 2008
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
I have an old school autotec xs 1500.1 and need to know how to hook up the outs to make it 1 ohm
Since it is a mono block amp, it depends on your subwoofer (s), and how you wire them to the amp.
Single 4 ohm sub would be just that, 4 ohms.
Single dvc 4 ohm sub, with both voice coils wired parallel would be 2 ohms.
2 dvc 4 ohm subs wired parallel would be a 1 ohm load.
Feb 20, 2015 | Ohm Car Audio & Video
Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
hope this helps :~)
Mar 03, 2014 | Car Audio & Video
Dvc wiring diagram
need the ohms of each coil and what the amp can handle in ohms
Dec 12, 2013 | Soundstream PCS-12 Car Subwoofer
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
Xtant A3001 Car Audio Amplifier Logo
304 people viewed this question
Top Xtant Car Audio & Video Experts
hoyzee1
Tom Chichester
FastHarley
FastHarley
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
