Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore coldspot I have a 4 year old coldspot. Twice in the past year the lights work but it is not running and the inside light panel is off. If I unplug it for a couple seconds and then plug it back in it works again. Why would it do this? I've cought it both time before too much damage was done
  • 943 Answers
Hi thanks for the question i would check the cold control what is happening is that the fridge gets cold enough but because of this bad control it wont send power to the rest of the fridge replace cold control thanks the appliance doc
Posted on Sep 22, 2008
Kenmore Coldspot 106 Refrigerator
It's 12 years old it's gone ,they don't last forever ! Compressor !
Aug 18, 2015 | Refrigerators
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Kenmore coldspot 106.53769202 will not cool fridge, have deg=frosted,vacuumed underneath and emptied drip pan, no air blowing into fridge. Had gnats inside while power was off for over a month.
Does the compressor run? Does the small tube get warm? is the inside fan working? does it have an outside condensor fan? Is power getting through the thermostat due to gnats between the contacts? Does the inside light work? need more info.
Oct 16, 2013 | Kenmore 50522 / 50524 Side by Side...
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker broken
first if you take off that panel there is a circuit board . unlpug the board and put it back to gether if that dont work then replace it... i sometimes get away with both! i can also get you that part pretty cheap... here is my site. grab the number and give me a call thanks.
Apr 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Dec 15, 2008 | Refrigerators
Freezer works but cooler isn't cold
Try unscrewing the light, bulb mine did the same thing I couldnt figure it out. It turned out to be the light switch! Everything is fine now.
Aug 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
268 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
