Question about Technics SA-AX720 Receiver
SA-AX720 no subwoofer signal?
Hi
I picked up a SA AX720 to hook up with the TV in my office at home but I can't get the subwoofer working.
I have a 42 flat screen an HDMI DVD player with a Captive Works Satellite plus a cable signal.
I also bought a set of Sony SA FT3H speakers for a very good price used, still in the box and thought I was doing pretty good. This six speaker system has a powered subwoofer.
When the Technics didn't seem to work, I pulled my Pioneer VSX-D711 from the basement system and hooked it up just fine and the subwoofer works great.
I put it all back together configuring the Technics the same way, even dug up the manual online.
I get sound from five speakers but no subwoofer....there's a line out for the Subwoofer but the Sony doesn't respond.
Sounds to me like the subwoofer section is fried in the amp....anyone else had this problem before?
regards
Ian
pitbullmedia@rogers.com
The RCA output for the subwoofer is for a powered subwoofer (a subwoofer that has its own built-in amplification). I have used a Klipch powered subwoofer for a number of years with very good results.
Posted on Feb 07, 2009
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Posted on Nov 05, 2008
Home theaters technics model sa-ax720 manual de itruciones
Here is a link to the pdf file you need for that model...
http://service.us.panasonic.com/OPERMANPDF/SAAX920.PDF
Jul 30, 2014 | Technical Pro SW-1501 Subwoofer Speaker
Overload
Probably dry joints around the power amplifier.
Mar 18, 2017 | Technics SA-AX720 Receiver
Trying to hook up SH-AC500D to SA-AX720 Receiver. I wanna know the right wires to use. Thank you
Connect the 6-channel analog outputs of the AC500 to the 6-channel analog inputs on the AX720 using 3 RCA cable pairs.
http://archiwumallegro.pl/technics_shac500d_procesor_surround_ddigital_dts-1215399983.html
Digital sources will enter the AC500 and be converted to 5.1 analog output.
Be advised, that input on the receiver will not allow any internal DSP manipulation. WYSIWYG.
Feb 04, 2011 | Technics SA-AX720 Receiver
Looking for user manual for Technics SA-AX720 receiver
You can download them, depending where you are, I have one!
Jun 07, 2009 | Technics SA-AX720 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Im having trouble connecting my xbox, cable box, and Hi def. tv
greetings, you should be able to use rca cables for simple connectivity. hook the x box up to the tv as you would normally on the back or side of the tv there should be audio inputs and audio outputs. xbox signal goes to input and rca cables from output on tv to aux or tv input on your reciever. then make sure that whatever audio input jacks you connected your tv to your reciever with are the same as the function or mode input on the front of the reciever. if you need more assistance look your reciever up on the manufacture's website and diagrams should be available in the search portion of the website
hope this helps
ryan
Feb 18, 2009 | Panasonic sa-ht930 Home Theater Audio...
Sony sa-w305
Hi bob,
yes I have the active subwoofer book, SA-W305 1998
If you let me have an e-mail address, I will scan and send you copies (8 pages) regards Brian.
P.S. I have been using the unit on its own, just connected to my new tv, and the bass improvment is fantastic.
I had to have the amp TA-VE150 repaired,by having the IC joints resoldered, due to overheating.
Aug 17, 2008 | Sony SA-W305 Subwoofer
Technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Jul 04, 2008 | Technics SA-AX720 Receiver
Technics SA-AX720
Look for lossing solders points or bad conections. Start to look on those components of hi wattage and components to get hot alot, those are the most common to have weak solders spots.
Also some equipment need to be clean because the dust can make problems.
good luk.
May 21, 2007 | Technics SA-AX720 Receiver
515 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
