Question about Royal 5300 Upright Vacuum
Royal upright handle fork spring replacement
I have an old(er) Royal upright. The handle fork spring is broken and I have a new spring, but I'm having some difficulty removing the bolt through the fork and spring. Do I need a bigger hammer or better technique?
    Novelist:
  • 97 Answers
This is actually fairly normal, and there's no real easy way to get that bolt out. Your best bet is to continue turning it as if you were unscrewing it while applying pressure to the opposite end. A narrow piece of metal can help, especially if coaxed with a ballpeen hammer. If possible, you can try to apply some pressure upward on the spring to keep it from holding the bolt too tightly, but this only works about half the time.
Getting the bolt back into place is also something of a nightmare, as you have to use your thumbs to hold the new spring in place while forcing the bolt back into place. I've had indentations on my thumbs from holding that spring many times.
Good luck,
-R
Posted on Sep 23, 2008
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Xl2600hhvacuum won't stand alone anymore, what is broken, is it a spring or some kind of catch missing
The detent that is mounted to the inside of the base cover is not working either because the screw holding has broken off or it is worn out. You could also have a worn out fan housing since that is what the detent catches to make it stand up. If the screw is broken off the only way to repair it is to replace the housing. Hope this helps.
Jul 15, 2013 | Oreck XL2600HH Upright Vacuum Cleaner...
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Eureka Smart 4870DT Bagged Upright Vacuum
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Handle won't stay upright
G3 has a handle return spring. Check to see if it is properly tensioned or broken
Sep 04, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My old hoover convertible will not lock in the upright position.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=682682
Generic problem for all Vacuums
My old Hoover convertible will
Posted by taylor2 on Jun 18, 2008
My old Hoover convertible will not lock in the upright position.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have a broken handle release lever and that would be inexpensive to fix or repair. You are either missing the spring or the handle release lever is broken. Feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Vacuums
Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Royal 5300 Upright Vacuum Logo
165 people viewed this question
Top Royal Vacuums Experts
Roger Potts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
