Question about Xerox DocuColor 12 Printer
No error code
The machine docucolor 12 print the first copy fine but the others missed the yellow and the other copy missed the black and the other print fine and the other half good and half missed the magenta but no have a code error or default system i changes the ibt, the waiste container, the copy printer, all the inks and also the power supply and i dont find the problem if any one cant help me???????????????????
  • cambo23 Sep 22, 2008
    i have another broken machine how can i fix that? what is the tranfer unit
  • 62 Answers
Arius is right, you have a cleaner cam clutch problem. It is slipping and cleaning any part of the image that has been produced already, leaving you with the remnants in your output tray
Posted on Nov 19, 2008
You must change ibt clutch.
Posted on Oct 01, 2008
  • 446 Answers
There is a prob in the transfer unit, you need to send this to a shop or call for service
Posted on Sep 22, 2008
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Jul 19, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Doc 12 Error Code
You Have to Clean a litle square reflexive patch that is located on the IBT Belt.
Just remove the waste developer botle, turn the orange handle CCW, remove the 2 external screws of the IBT Assy and pull out the Transport drawer and IBT drawer. clean the patch reinstall and thats it.
Feb 14, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
