Monitor Help I just set up a newer pc to my monitor it was working fine with the old pc but now that i have the new pc the colors dont come in right i tried changing the resolution from 32 bit to 16 bit and it still doesent fix it.
  • 2 more comments
  • Anonymous Oct 16, 2008
    my monitor color blew off to a pink colour
  • Anonymous Nov 08, 2008
    Mu monitor is pink also. HELP
  • pegalynw Jan 17, 2009
    My enitre monitor is suffused with a bright fluorescent pink light and I can't get it to go away. Help!
  • avegregory Jan 24, 2009
    Used monitor with previous computer without issue. When I hooked it up to a new computer (and installed the drivers) my screen is visible but has no color (a kind of back-light blue).
I had the same pink problem. In my case when I reconnected the monitor cable to the moinitor,I accedently bent a little wire in the connector. I straightened it out, reconnected it and it was able to mate with it's female counterpart and the pink went away. Hope this might help someone.
Posted on Apr 09, 2009
Slightly Blurred images on monitor
If it is a CRT monitor then the tube may be going out. A new monitor is about $129 for many of the cheap monitors I suggest you swap it for a newer flat screen.
Dave
Jul 04, 2017 | Mag Innovision InnoVision 786 PF 17" CRT...
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
"power saving mode"
Have you connected and then power on PC? does this monitor works any other PC? Is old monitor works in your PC? Some models of monitor has menu functin from what type of connector use to recieve data but they also automatically adjast it. Try to find if your model has any. If PC works in others and all connections is all right its better to bring your monitor back to shop.
Aug 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen shift
Try setting the refresh rate to 60 Hz. (Maybe 75).
Is it xp?
Right click an empty part of the screen, properties, under monitor (I think; I'm on Vista) you can choose the refresh rate.
Most LCD's should be at 60 Hz.
Jul 04, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
When I turned off my monitor last night, it was fine. When I turned it back on this afternoon, all of the colors were darkened and discolored. It looks like my contrast was change, but it wasn't, since no...
is this an lcd flat panel monitor or a crt? if it is a flat panel then you may be dealing with blown capacitors on the vga board inside. they can be replaced therby repairing the monitor. if it is a crt then just recycle it and buy a newer lcd monitor to replace this old one.
Jun 19, 2008 | Computers & Internet
Monitor problem
It sounds to me like your monitor is going......if the computer itself is functioning fine, and you have even reset the monitor to the default, and still having problems, I would say it's time for a new monitor. You can find reasonable ones on ebay. I got two 19" monitors off of there and I am thrilled with them. Just be sure to check the ratings of the seller before bidding or buying.
Good luck.
Dec 01, 2007 | E-Machines 6809 Notebook
Reddishness in the screen
Have you loaded the drivers which came with the monitor. This will probably allow you to change the settings.
Right click on an area of your desktop and choose properties. Look at the monitor and make sure the resolution is set to the recommended level possibily between 60 or 75 dependant on the model. Also you can get to the display card settings here and change them to suit. Dont get carried away or you can make it so that you cant see whats on the screen at all to be able to change it. Could also be that your monitor is faulty. Check with your manufacturer. It its an old telly type monitor maybe one of the "guns" have gone so you dont get the right colour mix of red green and blue. If this is the case you will need to get a new screen.
Oct 15, 2007 | LG Studioworks 563N 15" CRT Monitor
Computers & Internet Logo
455 people viewed this question
David Payne
David Payne
