Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore elite, will not make ice, but it does dispeanse, when i put bagged ice in it..
Will not make ice, but it does dispense when i put bagged ice in it...what could it be?
  • tnsmarchini Oct 08, 2008
    WILL A NEW WATER FILTER MAKE THE WATER GO INTO MY TRAYS
  • elmercdemayo Oct 12, 2008
    freezer cools properly, but does not make ice. when i place ice cubes into the dispenser, the freezer dispenses with no problem.
  • 943 Answers
Hi thanks for the question is the arm by the ice maker in the down position is the arm even there if that's ok you could have a problem with the water valve for the ice maker thanks the appliance doc
Posted on Sep 22, 2008
The ice dispenser is not dispensing ice. When you put a cup under dispenser and push in, nothing happens. Its a Kenmore Elite, model 106.5896*701
here are some places to look, check the dispenser switch is working and also that it is being activated by the mechanizm, check that the auger is turning, if not is the motor getting power but not working? is the selector switch in the correct position and is it making contact...
Aug 22, 2011 | Kenmore Side by Side Refrigerator
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Motor went out on kenmore ice dispenser. how do I change it.
need new auger motor remove ice bucket and ice maker remove back panel remove auger motor and replace put it all back in reverse.
Aug 17, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice does not dispense through door of kenmore elite side by side
take ice bucket out, dump ice, clean with hot water and let dry ,,,, put ice back in and try it ,,, bucket is most likely frozen up thru ports
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
