Washer Maytag Neptune
I turn the washer on it starts up for about a minute and shuts off My Maytag Neptune MAH4000AWW Starts, but only runs for 10-15 seconds & shuts off. Doesn't matter if I set it to fill or to spin. Just stops.
  • montegirl Oct 29, 2008
    I just had the Sears service man here and he says it's the motor. Good news is, the motor has a 10 year warrantee!!!
  • Anonymous Mar 18, 2014
    Dose Neptune hag perablams
    Sniper:
  • 88 Answers
Most likely the motor control unit, the MCU controls the timer (loop circuit). Best way to check is to just pull the MCU out and visually inspect it for burned components, although it is not always visible. You may need to make some involved voltage readings to verify.
Posted on Sep 22, 2008
MY NEPTUNE WASHER IS MAKING NOISE DURING SPIN CYCLE WHAT PART DO NEED TO REPLACE? MODEL # MAH4000AWW
If the noise starts before the drum starts to turn it might be the pump is obstructed. If it starts soon as the drum starts to turn then might be the drum bearing. If it is a knocking vibrating sound open the door and grasp inner drum try moving up and down and side to side . If there is any movement aside from the whole mechanism then the spider that holds the shaft to the drum is broken . Need a tech
Nov 23, 2010 | Maytag Washing Machines
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Check the door lock,if the latch does not fall in place correctly the door will send the message to the electronic board that the door is open.
May 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
