Question about Initial HDTV-322 32 in. LCD Television
My tv wont stay on and when it is it has whit lines and you cant see the picture
Rca #F35010ST
Rca crt tv guide plus wont turn off for several minutes after turning on tv and dish. I have a satellite dish so removing the zip code causes picture to become snowy and whit horizontal and vertical s
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | RCA F25432 25" TV
I want to connect sansui dvd to Samsung led television
There are typically 3 ways depending on the age of the dvd player.
Red White and Yello RCA Jacks (Out) of DVD to (IN) on tv Red, Green, Blue rca Jacks and red and whit rca jacks(Sound) Or, an HDMI cable which transfers both sound and picture.
Jun 17, 2014 | Televison & Video
Picture colors are seperated on my tv. the sound
Hi i did not want go to far whit this//
usely you will have to replace the convergence module there are 2 stk ic on it,and then use the magic focus button on the front panel/ if it not fix back your color alignement you will have to do manually whit the remote control.
but that needs some experience to do so...
hope that help ,its give a idea
have a nice day
Mar 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
RCA 32" 32V420T
YOU AVE TO CHANGE PROSESSOR IC I THING THE PARTS NO. IS TLC-A27VO2-TO, AND ADJ. YOUR SET WHIT SERVICE MENU.
Jul 02, 2008 | RCA 32V420T 32" TV
HDTV Setup
it wont hurt to run both to the set, they wont interfere with each other
Nov 28, 2007 | Televison & Video
Initial HDTV-322 32 in. LCD Television Logo
37 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
