Question about Electrolux Epic 6500 Vacuum
Vacum keeps turning off with warning lights
My vacum keeps turning off, the top warning lights come on. The bag with the dots in it and the cord light. I checked the bag which was not close to full. I changed the filter on top, which was not very dirty. When I turn the machine off it restarts then shuts down after about one or two minutes. I'm afaid to burn up the motor. Please advise.
  • 3 more comments
  • Anonymous Oct 15, 2008
    If I remove the hose from the body, it runs fine. As soon as I partially cover the air hole, it shots down and the warning light comes on, When the hose is attached, it shuts down within 1 second. The hose is not blocked.
  • Anonymous Nov 20, 2008
    same problem- same trouble light comes on and vacuum turns off.
    How do i change the control valve.
  • jenny_jenny Feb 07, 2009
    The same thing happened to my Electrolux Epic 6500 tonight. If it's the control valve causing it to keep shutting off, how do I change the control valve?
    What does it cost to change the control valve?
  • sunsetalert Mar 14, 2009
    vacuum motor runs fine until hose is connected or hand placed in front of opening on canister. Then it shuts off with bag light on, but bag is new. If it's control valve problem, is that something that can be fixed at home or must be serviced at dealer??
    Problem Solver:
  • 7 Answers
Actually the problem is that you need to change your control valve. The motor has an internal thermostat on it already so the chances of you burning the motor out are very slim. By changing the control valve, you will solve your problem. Very simple and quick fix.
Posted on Oct 29, 2008
    Problem Solver:
  • 7 Answers
It sounds like your vacuum motor is over heating to the point that the safety feature is engaging so not cause further damage. Take it into a shop to see what is causing it to shut off. You could also try taking it apart and checking for a hiding clog!
Posted on Sep 22, 2008
Same thing on my epic series 6500SR....I just took off the "hood" and disconnected the little tube that connects to the control valve...problem solved..
in the future I'll have to check the bag manually, I think I can live with that
Posted on Jun 25, 2009
  • 58 Answers
Just take it to a vacuum shop they can disconnect the bad controll valve and you will be back in business.
Posted on Jul 26, 2009
My vacum will not start a red question mark lights up. Can this be fixed?
This light indicates the bag needs changed. If you've done that, The possibilities are a clogged hose, clogged elbow at power nozzle, or on certain models a bad Control Valve Assembly. If yours has a dial on top, turn so the smallest dot lines up with the arrow. If it doesn't have a dial, you don't have to worry about a bad CVA. If you aren't using genuine Electrolux bags made by Home Solutions, then the bags pores will clog faster, which would cause the vacuum to shut off.
Jan 09, 2011 | Electrolux C101 Bagged Canister Vacuum
Kirby will not turn on
For the kirby to run all the switches need to be in contact. First check the brush head and make sure its attached properly, then check the plastic piece on the bottom of the bag (called the mini emptor) it should be all the way against the body of the vacuum. if all that is good check the cord where it runs up the handle and connects to the swiveling strain relief at the top... usually those cords go bad right there. If the cord is good, you probably need a new switch but before you spend the money on that expensive genuine kirby switch check the motor carbon brushes and the commotator on the armature where the brushes make contact.
Jan 02, 2010 | Kirby Generation 3 Bagged Upright Vacuum
1 ) how do you open the body of the vacum ? 2) How to replace the power cord? Epic 6500 sr
Very Carefully! LOL! Disconnect the hose from the door. Open the door. Remove the bag. Flip the vacuum on its top. You will then need to remove the trim pieces from the sides by sliding them toward the front of the machine(bag opening). Usually they won't want to go easily. The way I used to do it was by wedging a screw driver between the rear cover and the trim piece then gently tapped the side of the screw driver blade toward the front. Once you get enough hanging over you can grab and pull them the rest of the way. The vacuum should separate once the trim has been removed. ****I have to warn you. If you have never done this before it is extremely important to take note of how and where everything goes on an Electrolux. They are complex machines that are assembled in a fairly meticulous way.**** The best way for someone that has not had any training to replace the cord is by replacing the cord winder assembly that comes with a new cord. Otherwise you have to disassemble the cord winder. Not fun.
Dec 28, 2009 | Electrolux Epic 6500 Vacuum
Is the style c the right bag. The vacum cleaner only runs about 5 seconds before it says the bag is full.
If you have a 6500, the C bag is the right one. Try turning the dial on top of the vac to the smallest dot and see if the machine will run properly.
If it is still doing the same thing, take it to your Aerus/Electrolux dealer for repair. The control valve assembly (full bag control) needs to be replaced and I don't recomend that you try the repair.
Joe
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
My vacum is not powering up
Reason number 1 (not sure why Kirby Co. still has not fixed it) - improperly installed outer bag. You have to push the bag all the way to the unit so it presses the safety switch that is between exhaust and the vacuum shell
Reason 2 - defective cord - try wiggling it. If you know how to do it - try removing cord and supplying power directly to the unit using another cord or wire (ONLY if you know how to work with electricity.If you get zapped - do not blame me)
Reason 3 - bad power switch (instructions on how to replace it HERE)
Reason 4 (very unlikely) - motor KAPUT
Apr 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Mar 10, 2009 | Electrolux Epic 6500 Vacuum
Lux Legacy - Cannister Model
If it is what I am thinking, that warning light is just telling you that the cord is plugged in. Alot of the Electrolux models had this warning light.
Jan 05, 2008 | Electrolux Lux 5500 Canister Vacuum
Vacume will not turn off
I also have the same problem. this must be a latent defect. any recall notices from the company?
Dec 19, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
1,048 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
