Question about Dishwashers
GE Dishwasheer installed 09/04/2007. Model #GLD6700N00WW Serial # LM788127B It stopped in the middle of a cycle. Showed 81 minutes left and lights showing on Added Heat. Without realizing what I was pushing I turned the child control button on. It will not start or do anything now. Help!
  • 750 Answers
Hi gmrnelson,
Huuum here again.
You forgot to give me a solved rating before you signed off!
Thank You in advance!
Posted on Sep 22, 2008
Ge washing machine/stopped in the middle of the drain cycle
sounds like your pump has got jammed with a coin or usually hair grip.
Sep 18, 2016 | GE Washing Machines
How do I fix my GE True temp oven which shows F7 on the display?
https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Dec 11, 2014 | GE Ovens
GE High Efficiency washer model WPRE6150KWT--there appears to be a problem with the timer. A 47-minute load was still running after 80 minutes and the timer displayed 23 minutes left in the cycle. I've...
I would check screens on valve and hoses to be sure they are not stopped up. Also an unbalanced load can cause that if it's a top loader. Suspension rods would be the problem in that case.
Oct 11, 2017 | GE Profile WPRE6150KWT Colossal Capacity...
Everytime I turn on the dishwasher it says it will take a few more minutes to do the cycle then it did the time before. It started at 81 minutes and now we are up to 103. How can I make it go back down to...
Check inlet water flow to the machine. Check the drain filter in the machine. If all these are free from obstacles, there can not be any delay.
Hope the operating voltage is not fluctuating!
Sep 25, 2010 | GE Dishwashers
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Washing machine stops when there is 19 minutes left!
you need to have a tech out to look at it it sounds like the motor isnt going into high spin and /or cutting out on over load this is a problem with the g/e's there is no filter on this machine all the lint is flushed down the drain
Jan 08, 2009 | GE WBSE2090A Top Load Washer
Stops at 19 minutes left and will not do anything
As a first step, try cleaning the lint filter as per instructions elsewhere on this site.
Jun 30, 2008 | GE WSXH208A Front Load Washer
I just had a new GE washer delivered to my home today, June 24, 2008. All it will do is fill with water and than drain. The agitator cycle does not work and the spin cycle does not work. Model...
We had the same problem with our new GE washer.......the repairman just left. It's the circuit board on the motor that failed, causing the motor to stop working. GE will replace it under warranty.
Jun 24, 2008 | GE Washing Machines
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
