My chanel 5 cbs has no signal. we have been watching it for a month now and all of a sudden it has no signal. I checked the antenna signal on the set up and there wasn't any.I have the new dtv box and have been watching it for a month. and have been receiving all the channels. now chanel 5 is gone. please help me out.
YES I did. I just pressed the reset bottom on my digital box. thanks
Posted on Sep 24, 2008
My toshiba lcd is 5 years old and i been using it in uk now iwant to watch australian free chanels model no is 42x3030d
You have to select analog tuner to scan for the antenna signals.
You can select this in the menu.
Regards GJ
Jun 22, 2014 | Toshiba Televison & Video
Can't get cbs
Some TV's have poor amplification of the antenna signal, make sure you have a high quality RG6 signal cable, mount antenna with line of sight to TV tower as any obstruction can affect signal strength, AntennaPoint has directions you can use with a compass. If the signal is still low, try a HDTV booster amplifier. If the antenna is indoors, you need to move it around to find a hot spot that brings in all the channels (preferably in the attic).
Buffering on Netflix has nothing to do with the with the antenna, as you have to connect via the web to receive this service. In my opinion, TV's like Samsung are not very good with streaming video, and you are better off using some other device like an old laptop or external device hooked up to the TV to do this.
Jan 01, 2014 | Electronics - Others
On menu i dont know how to get chanels because i believe its got freeview built in i dont know if i need a wire or something or even to get 5 simple chanels please help
To watch television you need a signal, wether that be from an antenna, cable, or satellite. If you get a digital tv antenna you will be able to receive the free channels that are offered in your area.
Jul 28, 2011 | Televison & Video
This tv is not connected to cable or dish, but has an interior antenna. up to about 2 months ago, we could get network channels (abc, nbc,cbs) which is all we wanted. Suddenly CBS dropped out, says "no...
How far away is the CBS station? Are there any obstacles that would block the signal (say new construction)?
What channels do antennaweb.org or tvfool.com suggest you will get from your location? (Antennaweb is more conservative and assumes an outdoor antenna.) Do you need to rotate your antenna to get one transmitter or the other? Indoor antennas are more likely to get interference and direction issues.
You may want to restore your TV to the default and then rescan the channels. (This may or may not help. It usually helps more with scrambled information than lost channels.)
I hope this helps.
(good luck. I've had issues with my CBS and Fox affiliates (sharing a transmitter location). At first it was clearly my TV and the reset helped. Now I have no clue as to the cause - the external TV antenna gives a strong signal on the other TV. The problem TV says the signal is bad and this is the closest transmitter and antennaweb says I should get it easily. Even pointing the antenna straight at the transmitter doesn't help.)
Jun 10, 2010 | Element Electronics FLX1511B 15 in. LCD TV
Excessive static equally on all chanels on cb
You should always connect the CB directly to the battery as the accessory socket is full of noise. You also should choose a better antenna as these small glass mounts cannot hear signals well and magnify local noise. AM (CBs) radios naturally pick up noise as it is the nature of AM signals. Use your squelch to lesson this but too much can knock out you reception.
Feb 14, 2010 | Cobra Radio Communications
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
Converter Box Problem
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
Don't know how to change from cable to antenna
on the back of your set
there may be a small switch someone with 2 or 3 different options
Jan 20, 2009 | Sony KV-24FV12 24" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
