Question about Whirlpool Refrigerators
Whirlpool Side by side compressor overheating
Everything cleaned out completely. Seems to overheat, shut off, and does not turn back on. Freezer thaws, refrigerator goes warm. Can get it to come back on after a day or so. When running, the compressor is relatively warm to the touch, but I don't know how hot the surface should be normally. Help. Anything to do?
  • Jwalker45 Sep 22, 2008
    ED25CQXFH01
    SN: SH1330725
    Manufactured March 1998
    When I say cleaned out, I am referring to the coils etc, underneath. Minimal content in the fridge. No blocked vents, etc.
  • 43 Answers
Dear jwalker45, If the compressor is inefficent or if there is a restriction in the line (most likely the cap tube) the refrigerant can't circulate. when refrigerant expands it gets cold, when it's compressed it gets very hot. Bad motor windings will do the same. But u said tat u had cleaned the coils. so jus check out if you have a Fan down by the compressor is running. This will also cause the compressor to overheat.
If none of those things are an issue, replace the components on the side of the compresser. Replace all of them. If you have the same problem when you replace the components on the side of the compressor, you have a bad compressor.
Average repair cost for replacing compress can range from 350 - 450$
Posted on Sep 22, 2008
  • 750 Answers
Hi jwalker45
Welcome to fixya.com
What is the model # and the year of the fridge?
Waiting for your response.
Huuum
  • Neil Golan
    Neil Golan Sep 22, 2008
    Hi jwalker45
    Hi, again
    I think your fridge is ten years old and to put good money into bad!
    I read this report today and i'll share it with you!
    Huum,
    Repair or replace?
    When to pull the plug on your old refrigerator
    It nearly always makes sense to undertake simple do-it-yourself repairs,
    such as replacing a gasket on a refrigerator or a freezer.
    Typically, you'll also find a troubleshooting section for more-serious problems
    in the owner's manual.
    Should you pay for a repair or buy a new model?
    The answer depends mostly on the age of your refrigerator,
    how much you bought it for,and the cost of the repair.
    Follow these guidelines:
    When a repair makes sense.
    If your refrigerator is under warranty or less than four years old (three years for top-freezers),
    paying for a repair makes sense.
    Note that refrigerators under warranty might require service from a factory-authorized technician;
    readers have found them on a par with independent repairers.
    When a repair might be a wise choice.
    If your refrigerator is out of warranty and is four to seven years old,
    it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
    But you might want to buy a new model even at this stage,
    given that today's models are quieter and have added features.
    Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
    are 43 percent more efficient than conventional models built before 2001 and 56 percent
    more efficient than those built before 1993.
    When it pays to replace.
    The repair costs more than half the price of a comparable new refrigerator.
    Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
    six or more years old or a bottom-freezer or side-by-side eight or more years old.
    Thanks to better recycling programs, less than 10 percent
    of a refrigerator you replace is likely to end up in a landfill.
    Thanks for giving me the opportunity to help!
    Please do not for get to give a rating before you sign off!
    Thank You, HUUUM
  • Neil Golan
    Neil Golan Sep 25, 2008
    Mr Walker it is not cost effective to spend $450 to replace a compressor in what appears to me to be an older refrigerator made prior to 2000
    What were your results??
    Huuum
Whirlpool side by side, model ED25RFXFW01, is in garage - garage is cold this time of year and freezer/fridge warms up inside - is a garge kit available for this model?
Fridge Freezer errors COOLING Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling. Electrical There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply. PARTS You may order parts very cheap from here www.canadianappliance.ca/KBRS22KV.html TIME TO CHANGE YOUR FILTER While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently.
Jan 25, 2011 | Whirlpool Refrigerators
I have a Whirlpool gold conquest side by side model GS5SHAXNL00 that has a clicking noise coming from the rear. The freezer isn't keeping things frozen but the fridge side is nice and cold. I can hear the...
These models have two fans. One is located inside the unit. The fan inside blows air across the cooling coils. With the door open this fan is usually running other than defrost cycle. If this fan has stopped it will cause the compressor to overheat and the relay will cycle.
The second fan equally as important is located under a fiberboard cover accessible from the back of the unit at the bottom. This fan is usually noticeable by an air flow sound. Usually air flow is detectable out of the front grill. If this fan fails to operate, blocked due to a major build up of lint the compressor will overheat and cycle as you hear,
Hope this helps?
This is the fan inside the freezer.
Jun 25, 2017 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Freezer defrosted everything- fridge seems cold-
Sounds like the overload/relay is bad . Pt# 2188831 . This is the part attached to the side of the compressor , with 2 or 3 wires connected to it . Easily replaceable . Also , make sure the coils under the front of the refrig at the bottom , is clean of dust , lint , pet hair , etc.
Sep 13, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer will not get cold
Hi..
You need to check this following:
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
Good luck !!!
Regards
PCmania
Jul 10, 2009 | GE GSS25LGM Side by Side Refrigerator
Magic chef not cooling
The compressor is shutting down because it is drawing too much power and overheating. The clixon detects this and shuts off all power till it cools - then it resets and supplies power back to compressor until it overheats and problem repeats itself.
So what is responsible for overheating? Well, if there is an obstruction in the cooling system (high pressure side), the compression goes up past spec and the motor labors and slows down, creating less back emf, and increasing current consumption > then overheats and turns off. OR, if some of the the motor windings have had the insulation melt off, then the motor has less resistance than designed, more current goes through and again it overheats and shuts down. In this case your motor is fubar and needs to be replaced.
Apr 24, 2017 | Magic Chef CTB1922 Top Freezer...
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Whirlpool model ED25TW intermittent freezing
HI. it looks to me like a failing fan motor . it stops sometimes, then you close the door, and it goes. or could be hitting ice. remove the back panel ov the freezer, and check the fan motor
Oct 15, 2008 | Whirlpool Refrigerators
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
Hot point side by side
Could be stuck in "defrost" mode. Happens a lot. See if you can hear if the compressor is running or the compressor cooling fan is running (in back underneath the unit). Worse case is the refrigerant leaked out and you have a sealed system problem.
Sep 28, 2006 | Hotpoint FFU00 Side by Side Refrigerator
Refrigerators Logo
177 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
