Question about Compaq Computers & Internet
MONITER THE MONITER WILL FLASH ALL THE SCREEN COLOURS WHEN FIRST SWITCHED ON AND I HAVE TO KEEP ON SWITCHING THE MONITER OFF AND ON UNTIL A FIZZING NOISE STOPS THEN IT IS ALRIGHT UNTIL THE NEXT TIME I WANT TO USE IT AND HAVE TO GO THROUGH IT ALL AGAIN (COMPAQ PRESARIO SR1000 PRODUCT NO SR1519UK
  • 20 Answers
It sounds to me that you have starter problems or connection chaffing.
There ia a component called a starter that connects to the video portion of the MB. the starter then connects to the backlight to fire the backlight up and you could be having one that is dying fast. Seek a professional to replace or get the specific one from a distributer and install yourself if you have the ability. The wires that go from the video to the starter travel through the hinge section and over time these can wear and cause inteference to the screen. Might want to check this out also. Make sure you are experienced before attempting to open up a laptop. The final cause (worst case) could be the video itself, in which case your sunk and need a new MB.
Posted on Sep 22, 2008
Starting problem
Check all thick gauge cables from the battery to ground, solenoid and starter for tightness. If you find corrosion (it's caused by leaking battery acid) on battery terminals, remove cables and clean battery posts and clamps thoroughly with a wire brush and then scrub with a mixture of 25% baking soda / 75% water on an old toothbrush dipped in the mixture. Continue adding & scrubbing with mixture until fizzing stops. When fizzing stops, the acid has been removed. Next, wash down the whole top of the battery with the mixture and hose off when fizzing stops. Keep any caps secured to the battery! Do not let baking soda mixture enter the battery. You may need to charge or jump the car to get it started again - but the battery should accept a charge for the alternator at this point and keep from draining (assuming the battery is still good).
Aug 10, 2015 | Cars & Trucks
Tv started making a fizzing noise and now it is clicking as well with a slight movement of the screen during the click noises, goes up and down in volume now for a few days
is the fizzing noise when the screen is really bright? if so the scan coils on the tube have come loose and need glueing down with nail varnish i know it sounds strange but it really works
if the fizzing is coming from the tv then you have whats called dry joints
and this will need to be resoldered or the tv will shut down if you can do this yourself then the best way to find them is to remove the back and turn the tv on its side turn on the tv and turn off the light you will be able to see the dry joints sparking on the baord
hope this helps
John
Jul 06, 2011 | JVC AV32F476 32" TV
My brother placed a magnet on my moniter screen since then the screen shows different colours?
Have you displaced the magnet now? if not do it. Even after displacing the magnet retains the problem, you need to again keep the magnet as it was placed last time, this will discharge the electromagnetic process. Good luck
May 20, 2010 | LG Studioworks 700S 17" CRT Monitor
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When playing my X Box 360 the colours on the screen keep mixing
.this could be caused by an unsupported display setting for your t.v .are you using the right settings. to adjust them go to options in the xbox main meneu and then t.v options and adjust the screen disply. and then try your game. please write back here if this dosent help
May 08, 2009 | Microsoft Xbox 360 Console
Switching on 6600 white screen appears again getting switch off
try to format it..
press and hold call button(green button)+ * + 3 and power on button
until formatting letters appear...
May 04, 2009 | Nokia 6600
Screen all blue
Try looking into the blue CRT lens while its on and see if the coolant has congealed. You will be able to tell if it has bacteria growing as this can cause the blue to be unresposive and make your screen have a blue haze. The coolant will need changing if this is congealed with bacteria. This is a common problem in all projection tvs blue and green are more prone to this sympton red is not.
Mar 30, 2008 | Televison & Video
Buzzing/Fizzing noise at the back of TV.
Sounds like arcing from the high voltage transformer. i don't not recommend using it until you have it looked at.
Jan 30, 2008 | Televison & Video
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
