Panasonic DVD-LS82 error H03 - Televison & Video
SOURCE: error code on Panasonic LS50 portable DVD player
I also had the HO3 code...I re-alligned the laser..and now it reads the disk and shows the movie....BUT NOW I have no sound..?
I re-initialized the unit & still now sound...? IDEAS anyone..?
Posted on Jan 03, 2008
  • 123 Answers
SOURCE: when it tried to read
Fixing code H03 is very simple but needs some courrage and small philips screw driver.
The problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft. I do believe when we press the back space for long time it will take the laser lamb beyond its limit and get stuck at the end of the rotating shaft so the servo motor gets difficulty and resistance to get it back to tract.
All you have to do is open the back of the DVD player " 12 small screws"
When you remove the back cover be carful not to damage the cables .
You will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions.
Remove the whole structre and turn it upside down slowly .
Move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck.
And it will work perfect after that. Return the back cover and screw the 12 screws and you are done. Good Luck.
Posted on Apr 08, 2008
Agent Aaron
  • 265 Answers
SOURCE: PANASONIC DVD-LS85 DVD NOT SPINNING
Hey rick8468,
According to information provided by the manufacturer, a problem has occurred that may require physical repairs. There are however, two suggested solutions to this issue you may wish to try before consulting Panasonic technical support or your local repair facility.
The first suggestion is to simply turn the player off, then turn it back on to see if this error message is cleared.
The second is to power the unit down, disconnect any power supply (AC adaptor and battery pack), reconnect the power supply, and finally turn the product on again.
In the event that neither of these suggestions resolve the problem, the manufacturer has advised contacting your local dealer for further assistance. You may wish to make a note of the exact error message, as the numbers after the “H” indicate what the exact problem may be.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 27, 2008
SOURCE: panasonic dvd-ls91 erro code H03
Thanks for the solution.  I moved the laser all the way to the right and that did not fix the problem so I moved the the laser all the way to the left.  Still did not fix it so I tried moving the laser back to the right with the power off and it now works.
Posted on Jun 11, 2008
SOURCE: error H03 on a portable
check out this site, it helped me with the same problem.
http://www.pechorin.com/m/2007/07/05/panasonic_dvd_ls91_error_code_H03-296059.html
Posted on Jul 27, 2008
How to unlock panasonic dvd-ls82
We are not permitted to give that kind of information here.
Jun 14, 2012 | Panasonic DVD-LS82
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Code H03
SPRING MOTOR BAD
Aug 16, 2009 | Panasonic DVD-LS82
HO3 error panasonic DVD-LS80 disc will not play?
como hacer funcional el lente del equipo, tengo un error h03 VDV-LS80
May 26, 2009 | Panasonic DVD-LS80
Panasonic DVD ls 850 , H03 Code error
I have an LS82 and the following advice from www.avsforum.com fixed the problem for me. Note that the number of screws that hold the bottom on the machine vary depending on the model. Also the server frame might be plastic instead of metal:
Originally Posted by Hossam fixing code H03is very simple but needs some courrage and small philips screw driver.
the problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft
all you have to do is open the back of the LS50 " 12 small screws"
mad.gif when you remove the back cover be carful not to damage the cables mad.gif .
you will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions
remove the whole structre and turn it upside down slowly
move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck
and it will work perfect after that
return the back cover and screw the 12 screws and you are done
Jun 02, 2008 | Panasonic DVD-LS850
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Televison & Video Logo
435 people viewed this question
Top Televison & Video Experts
