Question about Kodak Office Equipment & Supplies
Printer just a few mos old. worked well for 3 weeks then black very very light could hardly see. INstalled new ink cartridge even tho showed 80% full.same thing checked and rechecked installation with still no results. KSN 658698
  • 2,326 Answers
If your printer is only a few months old, I would suggest to return it to the store and ask for a replacement or get it fix under manufacturers warranty.
Most electronics devices come with one year warranty.
Good Luck.
Posted on Sep 22, 2008
I put new cartridges color and black in printer. They are in the right places but it only prints black
New cartridges? When checking ink levels does it show FULL? Have you run thru the Maintenance solutions such as CHECK INK LEVELS CALIBRATE PRINTER-CLEAN PRINTHEAD-PRINT TEST PAGE ? But of course each model and brand is prob different . (Mine is A KODAK)Ive experienced this The solution for mine was certainly nothing technical. But it worked..the ink had apparently dried in the bottom of cartridge even though it was new) if you try this wear gloves it could get messy! Take an old saucer put a small amt very warm water on it just enough to reach the 'color holes' on bottom and set cartridge in it for a couple just couple mins my ink started flowing.then I moved it close to rim of saucer out of water for a minute , tapping off any excess water, wiped off with paper towel reinserted and it was fine. Now this may not be the answer to your problem but it wont cost to try and it wont hurt the cartridge. First thing tho I would check INK LEVELS make sure printer recognizes the new cartridge
Dec 27, 2014 | Office Equipment & Supplies
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
I have a f4480 hp printer. Used it about 3 times in last 6 mos. It was not printing with the black ink so I just bought #74 & #75 ink from Staples. Now the yellow light on the front of the printer...
If the ink cartridge in the printer is 6 months old, it maybe dried out and would need to be replaced with a new cartridge. When buying new cartridges from places like Walmart, Target etc. check the dates on the packages before buying. Sometimes the cartridges will set in the store too long and dry out.
Jun 17, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Installed new ink cartridges, computer shows low ink- not working
I would unplug printer and they turn back on and see, if not ininstall and reinstall cartridges and see.
May 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Canon PIXMAR MP150 E5 problem
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Apr 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
19 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
