I have a Numark cdn15/mpcd3 professional cd player with a 4 inch LCD which displays appropriate digital info relating to the disc being played. The LCD illumination no longer works making it difficult to see the info. Any ideas? Thanks Jim
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
NUMARK MP102 - When we put in an audio CD the CD sounds like it is spinning but the display says "NO DISC". Thank you in advance for your time.
it could be bunch of ting 1clean lens with soft cloth 2 it could be wrong disc,check n see if it as digital audio compatibility cd or it the unit just not reading the disc i think it is the wrong disc
Aug 03, 2011 | Numark MP-102 CD Player
Very reluctant to play burned CDs
What specific message or symptom does it display?
And commercial CD's are fine?? Look to the machine that created them. Make sure they're finalized.
Mar 05, 2010 | Numark MP302 2-Disc CD Player
Numark Axis 9's. . Problematic. Ahhhh!!!
Sorry, this isn't a solution but I just wanted to mention that I just got an Axis 9 and it is not playing burned CDs either. And I see another problem reported on this site specifically called "my axis 9 wont play burnt cds". What in the heck, Numark? Are all the Axis 9's this way?
Jan 18, 2010 | Nu Mark AXIS 9
Cdn 88 not reading cd
Hi, the main board will issue this (no disc) error code when the lens assembly is malfunctioning. this assembly incorporates the lens head and body and tracking rail. this rail has a motor and gear assembly that has to work in unison in order to track and read properly. the (no disc) error is signaling ga serious malfunction within this assembly. it is not tracking. this will cause errors and the lens will not be able to scan for data to transfer to the main board for track display and info.
numark does all the repairs in house so, you will have to send this unit to numark for the lens assembly replacement. it has failed.
May 22, 2009 | Nu Mark Numark Cdn36 Dual CD Player CD...
My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Numark cd mix 1
What kinda CD are you trying to play? The CD Mix 1 does not play CD-RWs. Do both bays give you this error? Need some exact info.
Jan 19, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Computers & Internet Logo
81 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
