On my epson printer, all my copies give a lined paper. the lines are pink and about 3/8 inch wide throughout the page. no one seems to be able to help and ever heard of the problem. help !!! thank you.
    Problem Solver:
  • 5 Answers
First I would recommend trying a new toner or ink cartridge. If the problem persists, try unplugging the printer for 5 minutes, then replugging it in and printing again. After that I would say the printer needs to be replaced.
Posted on Sep 22, 2008
Why do my copies have black lines down the paper?
if its just copies clean the small glass to the left of the large glass its called the slit glass and is usally about 12 inches long and 2 inches wide if it comes out on prints as well as copies its a drum or fuser check to see which is bad another way to test if its the slit glass make a copie from the large glass if no line its definatly the sit glass
May 27, 2014 | Kyocera Epson Workforce Pro Wp-4530 Wp4530...
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
nickerjo,
leaningpalmstudio.com
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Makes dark line on paper
if you are using your doc feeder check and see if there is anything on the small glass the one that is about an inch wide other then that could b fusing or drum issue
Jun 21, 2009 | Konica Minolta DiALTA Di200 Copier
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
1/2 inch wide black line appears on the copies
Please use the link provided below to download the user guide. The user guide and the troubleshooting guide will have detailed steps to solve this issue.
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PSC%201510-_E
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Black lines interferring with printouts
Not really sure what you mean by lines on your documents, but you could have excessive ink spilled on your printer rollers.or the page bar,,this can usually be remedies by taking the printer apart and carefully cleaning all of the surfaces the paper run against.
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
60 people viewed this question
jasbo
jasbo
