Question about NorStar Meridian M7310 Phone
Changing the password
i had to change to a new desk with different ext. When I try to change the password to the new ext. I keep getting an error message saying "INVALID PASSWORD". How can I fix this?
  • 30 Answers
The mailbox needs to be reset by your telephone admin person.
Posted on Jan 07, 2009
Hi I have a Nec DT300 at work. I am on a new desk. Do you know how I can change the name which is on the display.
If you have the Admin password then follow this procedure:
For a DT330 (24-Button with 4 line LCD)
Do not lift the handset and press the Speaker button
Enter #*#*
Enter the 4 digit admin password and press the Transfer button
The phone will now display 'Program Mode'
Select Base from the four options using the associated softkey
Enter 15 and press the select softkey 2 times
The Extension Number and Ext Name will be displayed
Find the Extension Number you want to change the Extension Name for using the + and - softkeys
Press the Mic button to go to the Ext Name line
Enter the New Name using the number dial keypad.
If you make an error the Recall button will delete a character to the left and the Hold button will delete all characters to the right of the cursor.
Press the Transfer button to accept the new name.
Press the Answer button 4 times or until 'Program Mode' is displayed.
Press the Speaker button.
The system will save the changes and return the display to normal.
Feb 14, 2015 | NEC Lands Phones
Have a dell desk top need to use my friend forgot password can u help
Hi
Start your computer
1. Keep pressing "F8" as the laptop computer starts.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me 4 thumbs up
Sep 03, 2011 | Dell Computers & Internet
Hi. My 4610sw IP phone does not boot properly. It runs the initial script and suddenly ask for the ext number. I set the extension and password numbers and it always shows an error "wrong password" I'm...
Where are you changing the password in Manager?
THe one you should be changing is under the "telephony" tab of the user. Erase what is there, and leave it blank, then when asked for the password, just press "#" on the phone.
Feb 18, 2010 | Avaya 4610SW IP Phone
How do you change passwords without knowing previous passwords in order to change voicemail greeting??
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
Apr 15, 2009 | NorStar Meridian M7310 Phone
Changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Apr 14, 2009 | Panasonic KX-T7633 Corded Phone
Toshiba Default code not working
Need to login to Admin mailbox 999 or 9999 (3 digit exts or 4 digit exts?) need to know admin password? once in follow prompts to edit maiboxes to reset password to default. Default is 997 and ext number,but the tech that setup your phone system could of change the default code(997).What Toshiba system do you have?
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
Cant log in to my yahoo e mail
try changing the explorer
u can try mozilla firefox
Nov 08, 2008 | Computers & Internet
D1232 extension programming issue
Welcome to Panasonic TD programming....
Even though the hardware doesn't exist, the numbers do. The universe of 101-164 and 201-264 are already taken. Oops, 200 might be available, 100 might be available. 167 and 168 and the 80's might work.
It's a 3 step process. Change 210 to 200 change 225 to 210 and change 200 to 225. There's your "swap".
Now, keep in mind that the XDP port for 110 is 210 and if your voice mail is analog.....Ah, but that's another thread.
Carl
Sep 19, 2008 | Panasonic KX-T7453 Corded Phone
All the instructions are in greek
while installing you should get the language option check it
May 14, 2008 | HP Photosmart C5280 Printer
Kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Feb 11, 2008 | Panasonic KX-T7630 Corded Phone
NorStar Meridian M7310 Phone Logo
185 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
