Question about HP Pavilion ze4300 Notebook
How to replace on/off switch on ZE4300
The power on/off switch still works but I need to press it several times before contact is made. I am afraid I'll have to replace the switch before not too long.
Where can I find some guidelines on how to open the computer without cretating too much damage. If I can't get the same type of switch I may fall back on a 'custom' made solution, but I first need to get into the box of course.
Thank you in advance,
Lucas
  • lautrerable Sep 28, 2008
    Many thanks for your help.
    Hope I can find the necessary detail in the manual now (drawings are quite small...).
    Regards,
    Lautrerable
  • HP Master
  • 4,338 Answers
First take off the bezel, along the top of the laptop. Check to see if it is actually the power switch on the system baord or if it is the power button on the bezel.
http://www.user-guides.co.uk/asp/search.asp?keywords=ze4300%20replacing%20power%20button
Posted on Sep 27, 2008
Wont turn on
If you think this has to do with the battery power, you also should check the contacts in the battery compartment. If the are not shiny, you can try to clean them with a dry cloth or a cotton swap. Don't use sharp tools in or close by a camera.
Make sure the battery is inserted correct and the battery cover should be locked correct.
If the camera was not used for a long time, perhaps some contacts are oxidised. Those contacts you can switch, try to switch them several times. Open and close the battery door several times. Press the on of button several times. Put the battery in and remove it several times. And hope the contacts will work again.
Mar 23, 2014 | Kodak EasyShare M883 Digital Camera
My kindle paperwhite wont get past the loading bar screen.I've reset my kindle several times, and it does the same thing.
Make sure it is charged.
When you reset it you press and HOLD the power button on for a slow count of 30. (Doing it for less does NOT work!)
If this does not cure the problem then there is something seriously wrong with it I'm afraid. You need to contact Amazon using their free CONTACT ME service on their website. They will either help you further, send a free repalcement or offer you a discount on a new device.
Mar 02, 2014 | Amazon Kindle Paperwhite
Problemes d'allumagethe problem is that i must press the power several time to have a normal picture
Check its main power on'off switch. If the contacts to this switch [inside it] has any loose connection, this kind of fault can occur.
Feb 07, 2013 | Daewoo DLP3212 32 in. LCD Television
Ntldr is missing is what i get on my hp pavillon ze4300
To repair missing or corrupted system file/s, boot up with the Windows installation CD then –
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Apr 01, 2010 | HP Pavilion ze4300 Notebook
When i press the power button it blinks a few times then off. what can i do?
there is some kind of shortage in the board of your laptop.
HOLD AND PRESS BOTH TOUCHPAD BUTTONS AND THEN PRESS THE POWER BUTTON.
IT WORKS IN SOME CASES.
DONT FORGET TO VOTE.
Nov 19, 2009 | HP Pavilion ze4300 Notebook
I Have an hp ze4300 laptop. it will not boot up?
Seems the laptop doesn't start up properly, the bios maybe corrupt or you have a hardware fault.
the bios may need to be reprogrammed and parts need to be tested to see what the problem is.
Theres not much we can do about this, you will have to take the laptop to a professional or contact hp for assistance / repairs.
Jan 03, 2009 | HP Pavilion ze4300 Notebook
My hp ze4300 will not turn on
Has there been a power surge meanwhile? If so, try unplugging the power cord, press the power button, reconnect power and try booting. Sometimes works.
Oct 19, 2008 | HP Pavilion ze4300 Notebook
Power Problems
i think your new battery has some problem
Sep 07, 2008 | HP Pavilion ze4300 Notebook
T30 Power up problem
The c-mos won't cause this. The power button is integrated into the keyboard, and uses the same connector as the keyboard to get power to the system. In most cases, the board with the power button (which is part of the keyboard) is worn out. Occassionally the keyboard connector will work loose or get a little corrosion or dirt and not make a good contact, check and clean the connection. If the connection is good, then I'm afraid you will need to replace the keyboard in order to cure the problem.
Jul 15, 2008 | IBM ThinkPad T30 2366 Notebook
Laptop hp pavillion ze4300
Probably bad memory or loose CPU module. First try removing and resetting CPU. You'll need to remove Keyboard, Palmrest, and heatsink and shield beneath Keyboard. You'll need a small Phillips screwdriver to remove screws and small standard size screwdriver to loosen screw holding CPU. After removal/reset, put everything back together and try powering back on. If still same problem, replace memory located on bottom of LT located behind door. Also, you may have a memory module located under Keyboard next to CPU that may be bad.
Jan 06, 2008 | HP Pavilion ze4300 Notebook
HP Pavilion ze4300 Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
