Question about Compaq Presario 2190US Notebook
Compaq presario 2190US
Noticed you got into the BIOS of the compaq, i am having the EXact same problem
what exactly did you do to get your's working again?
any input to get mine going would be very much appreciated
thanks
On the BIOS set up, it will show HDD (none) but if i return the old one the system will detect it.
This model laptop was installed with a 60Gb hard disk. When you installed a much larger hard disk the BIOS could not detect this hard drive.
Check the HP/Compac WEB site foe a possible BIOS upgrade that can support a large hard drive. Otherwise try a hard drive 120Gb or smaller.
Nov 10, 2012 | Compaq Presario 2190US Notebook
I need to change my bios chip for compaq presario f700 but i can't fin it in the mother board does some one knows where is it ? in the main board? exact place please
Changing the bios chips on that particular logic board requires soldering. It's a black chip with white writing on it, it's flat, and it has about 20 prongs on it.
Mar 22, 2011 | HP Compaq Presario F500 F700 and G6000...
After Window xp installed from Vista the wireless adapter failed to work.
install the wireless driver and check it and also update the bios. i suggest you to contact compaq to get the exact bios web link.
Jun 14, 2010 | HP Compaq Presario 730US Notebook
Compaq 2190 will not charge
Buy a new battery, they go bad all the time. I have to replace my Dell battery every 18 months.
Oct 16, 2009 | Compaq Presario 2190US Notebook
Wont stay off
sounds like it needs a new power supply.
Feb 04, 2009 | Compaq Presario 2190US Notebook
About your presario
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
19
Sep 24, 2008 | Compaq Presario 2190US Notebook
ASUS A7V8X motherboard
its not exact. its not made for compaq by asus so bios has to be used from asus site not compaq.
it wil fit in it and run but drivers and support is no longer a compaq
Aug 17, 2008 | ASUS A7V8X Motherboard
I am unable to charge my battery
I looks like the laptop can only work on 120V power supply. So only use 120V adaptor.
Dec 12, 2007 | Compaq Presario 2190US Notebook
Replace hard drive on Compaq presario 2190US
NO its a software crash use the installation disk you said you used......go through the blue screen allowing windows to boot up from that disc let it go right to the end and press "R" for the console (the dos line ) when there enter ....     chkdsk /p
Let Windows fix any problems. When finished remove the disc and I bet it will open windows for you.  Please come back and tell me how did you do because most people that I helped with this problem just run but you know old saying "what goes around comes around"
Oct 14, 2007 | Compaq Presario 2190US Notebook
Compaq Presario 2190US Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
