RE: SEARS SELF PROPELLED LAWN MOWER 917.374750..WHEN PULLING THE CORD TO START THE MOWER ( AS USUALLY IS DONE ) THE CORD FAILS TO MOVE. CKED THE UNDERSIDE FOR POSSIBLE OBSTRUCTIONS & FOUND NONE.
  • 706 Answers
Most lawnmowers manufactured over the past 15 years have a safety lever that needs to be pulled in to allow the mower to be started. This lever is normally located near the handrail and acts as a failsafe that shuts down the mower if you were to trip or release it . The intent is to protect you from injury if you let go of the handlebar. make sure you've puled in the safety lever before pulling on the cord .. otherwise, it shouldn't budge.. Hope this helps..
Posted on Sep 22, 2008
Mountfeild self propelled mower works nearly perfect pull the leever for the mower to move on its own nothing there cheked the slack on cable not the problem now it only works by pushing the mower any...
There is usually a belt that runs from the blade shaft to a small gear box. Front drive mowers have this belt mounted atop the deck, and rear drive mowers under the deck. The problem is usually a broken or worn out belt if all the linkage is working properly. Sometimes however, the gear box goes bad, or the parts in the wheels fail... (depending on the drive style) Check that belt! Good luck, and don't worry. Lawn mowers are pretty simple to figure out!
Oct 01, 2011 | Troy Bilt 5.5hp Self Propelled Mower
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
May 18, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Will not start
completly disconect self propled belt or gear should be able to mow til you fiigure out whats up with self pro some thing is jamming selfpro ps if you have to turn it upsidedown kill switch on
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
