Question about Kenmore 47722 / 47724 / 47729 Electric Double Oven
Kenmore double-oven (electric)
Code f7
  • Anonymous Dec 11, 2008
    need outlet size for double wall oven
  • 725 Answers
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Sep 21, 2009
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Thanks for using FixYa. Error F7 on your Kenmore means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 17, 2010 | Kenmore 49233 Electric Double Oven
Kenmore oven has error code F7
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem.
Jun 13, 2010 | Kenmore 41389 Electric Double Oven
What does F7 and beeping mean
I'm afraid F7 on that make of range usually indicates a problem in the control keypad in which case on your model the whole console panel usually needs to be replaced to correct the condition.
May 03, 2010 | Kenmore 47732 / 47734 / 47739 Electric...
F7 error code
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
Kenmore double oven
This is what f 7 means:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Will need to replace the oven control. Part # is WB36T10486 for black and WB36T10488 for white. Cost is $314.75 for black and $417.99 for white. You can get it at
Nov 16, 2007 | Kenmore 47772/47774/47779 Electric Double...
Double oven
ovenman, there's not a complete model number here but in the Kenmore line F7 is the code for a stuck function switch or bad keypad. Makes sense that it's telling you to start the lower oven. Try removing the ribbon cable from the board and cleaning the ends with an eraser. Reseat it and see if the code comes back. Make sure to kill the power before doing this. back.
Mar 28, 2007 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore 47722 / 47724 / 47729 Electric Double Oven Logo
187 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
