Cannot install it...it freezes my pc....and when i start on safe mode...it tells me that ,,,set up encountered an error during installation....error 0641
ROXIO CREATOR 2009 --- WON/T INSTALL. Message: "You must install Roxio Easy Media Creater 10 before installing the content" -- then it rolls back and quits.
I am trying to install Roxio 10 onto my Vista system. The small window pops up Please wait while setup loads. and never goes further than that. My system does not lock up or anything, just never gets past that. I have cleaned my regestry. I am guessing that I need to cean some install folders or something?
After completing the three pages of instructions for a clean install and trying to install Roxio Creator 2009, I got a message that I needed to install "Roxio Easy Media Creator 10 before installing the content." Part of the instructions for a clean install was to remove Easy Creator 10.2 DE which came with my Dell computer. I have contacted Roxio 3 times about this issue and have not received a response... After completing the three pages of instructions for a clean install and trying to install Roxio Creator 2009, I got a message that I needed to install "Roxio Easy Media Creator 10 before installing the content." Part of the instructions for a clean install was to remove Easy Creator 10.2 DE which came with my Dell computer. I have contacted Roxio 3 times about this issue and have not received a response...
You can't post conmments that contain an email address.
Aller dans le fichier c:windows\system32 et effacer ou renommer le fichier dsetup.dll en dsetup.old Ne pas oublier d'afficher les dossiers cachés. Solution qui ne fonctionne pas pour moi car je n'ai pas trouvé ce fichier.
is there any error messages? you should try install Microsoft.NET 3.5 manually and then try to install Creator 2009 again
You can download Microsoft.NET 3.5 here
Running the RegCure won't help. Use RevoUninstaller to remove the entire program (Roxio) as Revouninstaller will show you all the registry entries which you can delete it very easily.
2.) Update your CD/DVD burner drives. This can be done by going to the manufacturers website and checking for updates. (Ex: If you purchased your computer from Dell and it came with a built in burner, you'd check Dell.com for updates.)
3.) Update the PX Engine. This is Roxio software that communicates with the CD/DVD burner drives.
mine did the same thing, i called dell , they could not fix 7 techs tried and failed. so i went to http://support.roxio.com and download creator 2009 service pack 4 (52.5mb) u have to register it first, then download . follow the instructions . mine works now.
If you haven't already, you might want to uninstall then reinstall the program. Sometimes a program will seem to install correctly when it hasn't or, become corrupt over time. If you do this and continue to experience the same issues with the program then you may need to move onto troubleshoot the issue further.
During the installation of DirectX 9 portions of Creator 2009, the installation halts, it perhaps tries to roll back, gives an error....wizard was interrupted ... and cannot be completed.
Resolution Open My Computer (or Computer for Vista users) from your Start menu.
Go to C: drive -> Windows folder -> System32 folder.
Look for a file called dsetup.dll in the System32 folder.
Rename the file to "dsetupOLD.dll" or delete the file.
Reinstall Creator 2009 and follow the on-screen instructions.
