HP Officejet Pro L 7580-can't turn it on
When I push the power switch, the power does not go on. I have checked the plugs and other connections. Nothing seems to work. What am I missing?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1-try a different outlet
2-check for continuity in the power plug
3- if the two above are ok then the problem is with the power supply board of the printer.
4-open and check the fuse on the power supply board
Posted on Sep 22, 2008
    President:
  • 1,952 Answers
Its the power supply board error in ur scanner ...due to this problem...the input current will not falls on ur power board circuit ...if its under warranty..get it replaced as to ur problem ...else give it to service man to rectify ur board...pls u don try tis if ur not familiar with electronic and electric components...
    Genius:
  • 3,422 Answers
Please click on the below link there are troubleshooting steps recommended by HP which will solve your issue:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpd05351
Need to overide ink cartridge hp officejet pro 7580
I suggest you go to www.inkjet411.com for HP 940 ink series solutions/information on this issue.
Thanks
inkjet411help@gmail.com
Feb 21, 2013 | 2003 Chevrolet Monte Carlo
Recently i was sent an expired cartige by HP Now the printer officejet Pro 7580 does not print
Many of the cartridges are microchipped to ensure they originals and compatible, they often put an expiry on for no apparent reason. Many models will run a firmware upgrade but you have to go look for it. You should be able to return to your supplier. But HP are often very good if you contact them.
I hope this helps in some small way.
N
May 08, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
No connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Same as mentioned My HP Officejet Pro L7650 will not turn on. I a
try connecting the printer directly to wall instead of surge protector and see if that resolve the issue
Aug 17, 2009 | HP Officejet Pro L7650 Printer
I have an HP Officejet Pro 7580. When printing in
I think ur catridge must be empty plz fill ur catridge and then check
May 26, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Mar 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
The paper won't advance enough to print in our HP officejet 7580
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Mar 02, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro 7580 Scan Cover Installation
Hp links to the manuals for your printer. I would check to make sure you unlocked the scanner. make certain the scanner cable (is applicable) is connected in the rear properly.
Best Wishes
Here's the manuals for the printer you own.
http://h10032.www1.hp.com/ctg/Manual/c00862808.pdf
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Sep 26, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
226 people viewed this question
k24674
jasbo
jasbo
