Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Can't dial out
I connected the bluetooth to a 8700c blackberry + the bluetooth works fine for incoming calls, however i can't dial out, even after i disconnected the bluetooth. how do i fix this problem
  • sarah553 Sep 22, 2008
    how do i reinstall the firmware?
    Genius:
  • 1,847 Answers
This seem issue with the firmware. get the firmware reinstalled then try.
Posted on Sep 22, 2008
  • Legin Varghese
    Legin Varghese Sep 22, 2008
    there is no issue with the hardware as you can take incoming call sucessfully.
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
BlackBerry Pearl 8130 - no ring tone on incoming calls, can only receive text and voice mail
In your BlackBerry Pearl 8130 handheld go to Profile and then select Advanced, Highlight any one the profile then click on menu key and then select Edit and then select Phone, Then select Out of holster, Press menu key select the tone. You will be able to hear the tone for incoming call.
Oct 18, 2009 | RIM BlackBerry 8700c Cellular Phone
My blackberry 8700c bluetooth does not work
In this case you need to re-instal the software of you're blackberry Handheld but still if it is not working please walk into the service center to chack the Hardware parts of Bluetooth.
Jul 09, 2009 | RIM BlackBerry 8700c Cellular Phone
Blackberry 8700c Problem.
Your Blackberry 8700 has a older version of bluetooth which does not allow file transfer. That is the reason your phone does not receive anything. The bluetooth version on your phone is designed for hands free bluetooth devices only.
Jun 19, 2009 | RIM BlackBerry 8700c Cellular Phone
Cannot Voice Dial from Bluetooth H700, Address book won't transfer
May not be the best one, but I just removed my battery and put it right back in and it works again.
Oct 17, 2008 | RIM BlackBerry Curve 8310 Smartphone
Answering blackberry with Plantronics ATT V521
I pull the battery from my blackberry and I can use the voice dialing again.
Jun 20, 2008 | GPS
Can i send images to a backberry 8700c through bluetooth?
i think this it is a major problem with bluetoothing and blackberry mobiles.
Jun 05, 2008 | RIM BlackBerry 8700c Cellular Phone
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
52 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
