Question about Linksys EtherFast 3116 Port 10/100 Ethernet Switch [ EF3116 ] (104857)
Didn't recognize uplink
I tried to put our equipment on the ef3116 switch and when I did that, I couldn't get anything to logon. I put the network feed into port 1 and ran everything els off of that. Am I doing something wrong?
  • 787 Answers
Not really, you just have a minor misconception. The network feed is not suppose to plug into the uplink. The uplink is for connecting 2 switches together so they act as if they were one switch.
Posted on Oct 06, 2008
Why doesn't has uplink board for MA5608T?
MA5608T with compact design, there's no uplink board for it. The main control board MCUD/MCUD1 provides uplink ports? Huawei MA5608T OLT Access Network Thunder link com
Dec 05, 2016 | Computers & Internet
When I Connect Two Cisco SRW 2024 Switch with Uplink Port ,Uplink Port get Disable
Most newer switches have auto detect MDI / MDI-X ports, but try a cross-over cable since this model is end of life.
Feb 26, 2013 | Linksys Cisco SRW2024 24-port webView...
Steps how to install 4-port Cable router what steps we should do..
This is a switch so if it is the only thing that is attached to your modem it will not work for more than one device. The first device that it talks to will be the only one with internet. If you want to use internet on more than one device you need to get a router. This will make it so you can use more than one device on your network.
If it is not the only thing attached to your modem and a router comes first then setup is simple. You just have an Ethernet cable go from any port on the router to the "uplink" or "internet" port on the switch. Once this is attached you can attach anything else to the switch and it will have internet.
May 11, 2011 | Uplink Computers FS105 5 Port 10/100 Mbps...
Why will my walmart.com not go through I switched to warner cable instead of att and put va router on and can not get my walmart associates log in to go through
Without knowing your network setup, I can list a few general ideas.
First, try powering off your Cable modem and disconnect all cables to it and unplug it for about 1 minute. Then reconnect the power. After about 30 seconds, reconnect the coaxial cable (thick black round cable with the wire sticking out) and screw it on tight. After about 30 seconds, reconnect the network cable from your cable modem to your router uplink port (if it has one...some newer routers have automatic uplink detection).
If that doesn't fix it, you make have to call tech support at Time Warner so they can register your equipment in their system.
Apr 13, 2011 | Microsoft Windows Vista Ultimate Edition
How to connect the network cable
you will have 8 ethernet ports in this switch... One port is for input all the other ports are for output...
If you dont have any dedicated uplink port, then any port can be used as an uplink port and other ports becomes downlink port...
The Lan slot of router should be connected to the uplink port in switch.... you can connect upto 7 computers in this switch(in downlink ports)...
Dec 13, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
How can i reset the linksys ef3116 to default if it doesn not have a reset button or knowing what the ip address is on the switch?
You can use a port scanner to find its IP address, such as Angry IP Scanner http://www.angryip.org/w/Download and reset it from there. It is most likely 192.168.1.x or 10.0.0.x.
Jul 07, 2010 | Linksys EtherFast 3116 Networking Switch
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
When I plug a cable into port 8 it will shutdown the switch
Your router supports a total of 8 connections. However, on the back there are 9 physical ports. Port 8 has two physical connectors where one (we will call it port 8a) is used to connect to a PC and the other (we will call that port 8b) is used as an uplink port. The uplink port (8b) cannot be used if something is pluged into 8a. If you are trying to use all 9 physical ports that is likely ther problem. If you need more than 8 devices connected to your switch get another 8 port switch (any brand will do) and connect the two switches via the UPLINK port with a 7 foot CAT-5 cable. Do not use a CAT-5 patch cable less then 7 feet long to connect two network devices together such as computer to switch or switch to switch as that will probably cause another problem with timing.
Another possibility is that the device at the end of port 8 has a malfunctioning network adapter. Try connecting a laptop to port 8a using a 7' CAT-5 cable. You may also want to try pluging the problem cable into another port as a way to test if the problem is somewhere along the cable run.
Oct 29, 2009 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Ef3116 has different up and down speed.
PC1 may have a defective NIC card. Also, verify that PC1's NIC card is using an up-to-date driver and that it's interface speed and duplex settings are set to auto-negotiate.
Jan 09, 2008 | Linksys EtherFast 3116 Port 10/100...
Linksys EtherFast 3116 Port 10/100 Ethernet Switch [ EF3116 ] (104857) Logo
164 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
