Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Print problem the fax page is very dark. anything printed is very dark. not the text,...parts of the page that would usually be white, why would this be happening>
    Genius:
  • 2,120 Answers
Have you tried a new GENUINE Panasonic Toner Cartridge?
Posted on Sep 23, 2008
What will be the reason for canon sensys fax-L 150 coping dark page but faxing and printing is ok.
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
Sep 30, 2016 | Canon i-SENSYS FAX-L150 Laser...
Typing white text on black background
Normal printer ink does not print white - it does every other color, just not white - if you really need white printing, you should contact a professional printing company, they can generate white printing,
Apr 08, 2012 | Adobe PageMaker 7.0 for PC
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Pages printing with white lines through the text
replace the cartridge and it should be sorted!Good Luck!
Dec 29, 2009 | Canon FaxPhone B95 Plain Paper Inkjet
I have a Canon MP610 printer.The Test page prints ok.The copy fuction is perfect co;our and black and white.When printing from a file saved on computer the text has a sepia tone not black and white....
just chk the properties or the colour cobinations if you choose text for printing out than it will only print text and if it is too dark red that means it is connected with some wrong colour wire
Jun 11, 2009 | Canon MP610 Photo All-In-One Printer
Black streaks on prints
Where the original page that you wish scanned/faxed there will be a device called a "scan part". This device "reads" the paper to be faxed/scanned as it passes. It usually is found very near where the paper to be faxed goes in.
If there is a spec of debris on this part it will cause a fine line straight down the document. If its dirty, the document will be too! Just give it a good cleaning and you should be fine.
Did this help? Click "FixYa" below!
Thanks
Len
May 29, 2009 | Brother IntelliFAX 4100 Laser Fax
Copying problems
You must change the power supply
Apr 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Printing problem
Are the problem prints all from the same source? If so the problem could be on the transmission end. Can you connect to your fax and print to it from a local workstation? If so print several images with dark solid patterns and see if it is actually the printhead. Try printing in cyan, magenta, yellow, and black colors to to rule out each individual printhead.
Jan 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
56 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
