Reset Canon MP258 error 5B00 or P07
Indications
When the printer is turned on will show an error MP258 P07 in LCD panels and monitor screen will pop up an error 5B00.
Resetter Canon MP258
1. The printer must be in SERVICE MODE, the way
2. MP258 printer is turned off and plugged the power cord.
3. Press the STOP / RESET and hold, then press and hold the POWER button.
4. The power button is pressed, release the button STOP / RESET, then press the STOP / RESET two times, then release both buttons simultaneously.
5. MP258 printer will process (rather long), then the LCD Panel will show the number zero (0)
6. The computer will detect NEW DEVICE, Ignore it .....
7. This situation indicates the printer is on and ready to reset SERVICE MODE.
8. Download ServiceTool_V1074 for MP258
9. Extract file ServiceTool_V1074
10. Prepare 2 paper in the printer (this is to print at the time the reset process)
11. Run the program ServiceTool_V1074
12. Click the "MAIN", then the printer will proceed, then MP258 will print one page with the words "D = 000.0"
13. Click " EEPROM Clear ".
14. Then click "EEPROM", and the printer will print the results MP258 Re-setter.
"TPAGE(TTL=00000 COPY=00000)"
15. Turn off the printer by pressing the POWER button or unplug the power cable
16. Turn on the printer, and the printer ready to use
I hope this information helps. Thank you for using FixYa!
what is the lates resetter in canon mp258 sir?
resetter mp258 =http://www.mediafire.com/?aqyoh69jfiw18q...
Thank's sir
it work, tq
You need to use sirens injection to pump the ink
SOURCE: my printer canon pixma mp258
Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge. Step to resolv this error Step 1 : Turn Off Printer Step 2 : Remove Cartridge Step 3 : Refilling the cartridge Step 4 : Reinstall the cartridge Step 5 : Turn The printer ON If it still does not work you can use the following methods How To Reset MP 258 error 5200 Step 1 : The printer is off and plug the power cord. Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Step 4 : Release both buttons simultaneously Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0) Step 6 : Computer will detect NEW DEVICE, Ignore it... Step 7 : Press the power button, then the printer will turn off Step 8 : Press the power button again, then the printer will be ready to use
SOURCE: i refilled pixma canon mp258, message e, 6 and 1
hi....press reset button and colour or black button in the same time until the error gone...
please vote if this can help you....
SOURCE: my canon pixma mp258, the
I have this problem too...I can see is my ink inside the ink hose is stuck.....can't go in to the ink Cartridge....so that means problem is the ink ...stuck in the middle of the ink hose...if anyone how to run the ink in the ink hose...please help me..=]
SOURCE: error code 5200 on canon
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on if error still persist replace Ink cartridge or print head.
SOURCE: canon pixma mp258 error 5b00,
I searched under mp258 on the canonusa.com website and found nothing on it.
There was an mp250, though. Was this model marketed in the U.S. or abroad?
When I input error 5b00 I came up with a series of hits:
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#ServiceAndSupport
The above describes how to shut the printer off and turn on again.
There were quite a few hits, but none referred to the 5b00 problem, specifically, unfortunately.
