Question about Baumatic 23 in. B10 Electric Cooktop
Indicators our hob has just turned off the heat and 'L' has appeared insteand of the nornal 'H' indicator any ideas anyone - i'm starving
  • Aardvark421 Oct 20, 2008
    Thanks for the unlocking solution.
    How do I prevent it from going into lock mode the next time I turn it off?
    I can't find my manual.
    Cheers
The 'L' means locked - to unlock turn on hob, hold down front right hand side plate control and minus botton to unlock - see manuals for further details
Posted on Sep 23, 2008
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
When I switch on, there is a pad lock symbol that gets displayed and I can't turn up the heating elements.
Thank you for using FixYa. The pad lock symbol is a child safety device to prevent accidental operation. Press or touch the area on or around the padlock symbol and the indicator will go out and thus allow you to use the hob
Mar 04, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Baumatic 23 in. B10 Electric Cooktop Logo
438 people viewed this question
Top Baumatic Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
