Question about Garmin eTrex GPS Receiver
Garmin etrex screen too dim to read
Left garmin etrex on dash of car while driving, now am unablle to read screen.
  • Anonymous Mar 18, 2014
    The screen on my Garmin 240 blue fishfinder is very dim to the point I can not read it, what could be the problem
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Posted on Nov 21, 2008
    Problem Solver:
Put new batteries in. guess the others were too weak
Posted on Sep 23, 2008
Garmin etrex 12 channel gps, screen very dim contrast with new batteries
For the Etrex Legend you can click the page (top right hand) button till you get the main menu, select setup then display. Point the click stick down until the bar on the left is highlighted. You can then move the bar up and down until you get the contrast you want. You could first try clicking the square near the top right and selecting restore defaults, but if the default contrast is not to your liking then you can change it using the bar.
It is probably similar on related models such as the Venture or Vista, if in doubt check your manual.
Dec 30, 2010 | Garmin eTrex Legend GPS Receiver
My owner's manual and reference guide was "drowned" while fishing. I need another one for my Garmin eTrex Legend personal navigator.
hi,
This should be the manual your looking for:
Garmin eTrex Legend Manual
This is a pdf file so you will need adobe or foxit to read it, I;m sure that most pc's come with adobe on them though.
I hope that helps..
Mike
Sep 01, 2009 | Garmin eTrex Legend GPS Receiver
Garmin etrex legend and external antennas
Check the Garmin website for external antennaes. I have this problem too, and get around it by placing the unit on my dashboard under the windshield. Never had a problem getting a signal there.
Aug 07, 2009 | Garmin eTrex Legend GPS Receiver
My eTREX VISTA won't get a satelite fix any more
The unit needs to have the screen facing up. The unit will not read if it is vertical. Garmin cust serv finally helped me with that one. Once you turn on the unit, it could take up to 20 minutes (usually about 3) to grab satelites.
Mar 26, 2009 | Garmin eTrex Vista Cx GPS Receiver
Screen is hard to see
click on setup and ajust the brightness or press the power button shortly
Mar 24, 2009 | Garmin eTrex Vista GPS Receiver
ETrex Legend screen issue
Due to a new satellite launched this year, the WAAS is affected. Disable the WAAS, go to Garmin and download the latest software version FOR THIS UNIT. Install, enable WAAS and you should be good to go.
Let us know if this solved your problem. Thanks.
Nov 13, 2008 | Garmin eTrex Legend GPS Receiver
Display on etrex Legend is dim
Have you tried Main Manu / Setup / Display and then adjusting the contrast?
Jul 07, 2008 | Garmin eTrex Legend GPS Receiver
A dark screen might be the result of a poorly adjusted display contrast. This can be altered by accessing the Setup menu and selecting Display.
Feb 01, 2008 | Garmin eTrex Legend GPS Receiver
Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Nov 04, 2007 | Garmin eTrex Vista Cx GPS Receiver
Garmin etrex GPS
If it is posible to, which it should be, go to menu, then setup, then units. Use the position frmt field, your best bet. Hope this helps!
Jul 25, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
653 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
