Align the motherboard in your mind, so that we are both looking at it in the same direction;
Processor to the top, Ram Memory slots to the right, the four white PCI slots to the bottom.
The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel go to, is the Front Panel header.
The Front Panel header for the Syntax SVM266A is below the IDE 2 connector. It is labeled Panel 2
(Harddrive plugs into the IDE 1 connector, optical drive/s plug into the IDE 2 connector)
Panel 2 is mounted horizontally. It is parallel to the IDE 2 connector.
There are 4 pins across the Top row, and 5 pins across the Bottom row.
The pins are numbered. Even across the Top, Odd across the Bottom.
1) Starting from the Left side going towards the Right, for the Top row;
Pins 2, 4, 6, and 8. There is no Pin 10, just a blank spot.
2) Starting from the Left side going towards the Right, for the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
If the Power On LED light is dim, switch the wires around.
B) Pins 6 and 8 are for the Power On switch.
C) There is no Pin 10
D) Pins 1 and 3 are for the Harddrive activity LED light. (HDD LED)
Pin 1 is for the positive wire.
If the HDD LED light is dim when operating, switch the wires around.
E) Pins 5 and 7 are for a Reset switch, IF a reset switch is used.
As for a motherboard manual,
http://web.archive.org/web/20060206024804/http://www.syntaxgroups.com/support/downloads.php
Scroll the page down to about 3/4ths the way down, until you come to the bold heading -
SVM266A
Click on Manual.
This is a PDF file. It may take up to 30 seconds before the first page comes up, and additional time for the file to fully download.
For additional questions please post in a Comment.
Regards,
joecoolvette
