Question about Whirlpool GHW9300 Duet Washer
Taking off front bottom toe panel
How do you take off the front bottom panel to clean the filter?
    Sniper:
  • 88 Answers
There are three 9/32 hex head screws along the very bottom of the panel, you have to look under the curve of the panel to see them, take those out and pull down and out on the panel.
Posted on Sep 22, 2008
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
I am getting a musty smell from the washer and from the clothes that come out of the washer. I have heard that there is a filter inside the toe kick panel that can be cleaned out. Is this true? What else...
true remove toe panel and wash murk out of plastic filter,,replace tightly or it will leak...also wash unit out with 12 to 16 ounces of bleach as needed...always unplug first
Aug 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
From what I have read, I need to clean the filter in my Frigidaire Affinity washer, I believe it is the 6000 model. When draining, the pressure of the water being drained is very low and I have to respin...
You will need to remove the lid by taking out the two screws that hold it down.
Then you will need to remove the screws that hold the control panel in place.then open the door and lift the bottom edge of the door boot to remove the retainer spring. then remove the front panel.
Then once the panel is removed you will be able to see the drain boot that goes to the drain pump.
loosen the clamp and pull the boot down so you can get at the coin trap.you should be able to push the trap up from the bottom of the boot it can be a little finiky but works. after every thing is clean you should be able to put it back together and work just fine
Jan 08, 2011 | Frigidaire Affinity ATF6000F Front Load...
How to clean a affinity frigidaire front load washer drain pump filter?
remove the toe kick panel just below the front door and its located right below the drum
Oct 01, 2010 | Frigidaire Affinity ATF6000F Front Load...
Samsung model WF218...not draining
Just follow the few steps here as follows. First switch off and unplug the mains. Now you look for the screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water in the tub bottom. Examine your pump also, clean out the impeller. Carefully refit all. For some front loader models after removing the bottom toe panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment. Check the exit hose of the washer for blocks.
The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there is a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.
Now your machine will be in good maintained condition. Hope this would have helped you.
Jul 22, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Wont drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For most front loaders:
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
You could also check the exit hose of the washer for blocks. Next snake out your wall drain, it helps.
Jun 12, 2010 | Samsung WF337AA Front Load Washer
Problem in out going water from the machine.Some were block?
For most Bosch washers, the filter is to be found at the front behind a removable plastic toe panel at the bottom. Remove this panel (3 screws underneath). If you find a hose there it is to drain excess water.Unscrew filter anti-clockwise, keep plastic bag to collect dirty water, etc. Clean and refit carefully.
Pl give me a 'very helpful' rating, thanks!!
Jun 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
How do you take the access panel off the bottom of the dryer to clean out the build up. There are two clips at the top of the panel below the door section. How can I remove the access/kick panel to clean...
Insert a putty knife about two inches in from each side (where the toe panel top seam meets the dryer front) to release the clips. With the clips released, the toe panel will open from the top and can be removed. You may want to also remove the air blower cover and clean inside the duct chute and the squirrel cage motor to ensure it is also free of lint. You will need to remove the lint filter BEFORE removing the cover or you will have difficulty removing it. If you have any questions, please post back with your MODEL NUMBER. I hope this helps you.
NOTE: Make sure you UNPLUG the dryer PRIOR to servicing anything inside the cabinet. Dangerous voltage is still present even with the unit shut off.
Mar 16, 2010 | Dryers
Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Oct 29, 2008 | Kenmore 62602 Electric Dryer
Washing Machines Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal De
