Question about Garden
PBC-3046YE GARDEN STRIMMER
I stupidly lent my Ryobi strimmer to a neighbour but when he returned it he had lost the bottom part and screw that holds the spool/string on!
Can I buy this part?
Thank You
Yvonne Giugno
kizzygiugno@live.com
rycgl
  • 1545 Answers
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Jul 10, 2010
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
Jul 09, 2010 | Ryobi Garden
Cannot undo nut on bottom of Strimmer
Make sure you are turning the nut to the right to loosen, if you are already doing that but cannot hold the line head still to loosen the nut some feature a hole to insert a screwdriver or pin (supplied with the trimmer) or if yours does not have that: use a nylon strap or even a leather belt to wrap around the head, and then clamp the loose end in a vise or quick clamps and it will hold it in place well enough to loosen the bolt.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Ryobi strimmer
i can not take the cover off to put the line back in
Jun 02, 2010 | Homelite Mighty Lite Lawn Trimmer
How do i change the line on my bosch garden strimmer, as it has broken
As it was impossible for me to get cap off spool I used a screw driver to prize off lid. If i ever need a new garden strimmer I will never ever buy this model again. It was so frustrating I felt like throwing it over the fence and buying a black and decker one.
Aug 03, 2009 | Garden
How to retunr ryobi strimmer 30 cc engine
Try turning the mixture and air screws all the way again and then out only one and a fourth turns. One and a half turns is only used on larger engines (riding mowers, push mowers). From one and a fourth turn you should be able to do a better ajustment.
Jun 21, 2009 | Ryobi Garden
Ryobi model RCT2800B grass strimmer will not start
close your carb adjustment screw a bunch of turns... yours may even be missing.
Apr 19, 2009 | Ryobi Garden
Garden Logo
154 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
