Question about Motorola Mobility V360 Cellular Phone
Mxit keeps disconnecting(little blue planet with red line through)
I need help to solve this i tried everything!! pleae help me!!!!
  • 1 more comment
  • Jay-Jen Sep 28, 2008
    I have the same problem. I have tried everything!!!!. Mxit keeps disconnecting me( little blue planet with red line through it) Please help.!!!!
  • lemma12345 Oct 09, 2008
    I have the same problem. Ive tried different mxit versions allready but nothing works. Ive even deleted most of my contacts and swopped my sim.
  • lemma12345 May 04, 2009
Posted on Oct 02, 2008
PLZ HELP.MY NOKIA 5130 XPRESSMUSIC'S MXIT KEEP
This would most probably be because your mxit settings have been applied to use http (or wifi), this setting can be changed by going into your mxit settings and changing you connection setting from HTTP (or wifi) to APN
hope this helps
Feb 28, 2012 | Nokia Cell Phones
I need my mxit pin for this number 0747566500 but lost the sim card
There are two ways to go about solving this problem.
  1. Restore your sim card by going to your service provider's nearest help centre.
  2. Contact the Mxit support staff and confirm that that is actually your cellphone number.
Feb 28, 2011 | Amazon.com Facebook Apps
Why does my playstation 3 keep turning off and the red light keeps flashing?
This can can be any one of numerous issues. The first step toward setting everything to rights is to discover what the light is trying to communicate, outside of the obvious fact that your system is not working. First, disconnect everything from the unit, power cable, HDMI, component cables, controller-charging cables or anything else you may have connected.
Allow the unit to sit and cool off for a few minutes before re-attaching all the component wires. It is a good idea to begin with just the connection to the television. You can also try a manual reset of the system if the above steps do not work, simply press and hold the power button for ten seconds.
If none of the above works, you are dealing with a serious PS3 flashing red light issue. This could be a faulty power supply, dead hard drive or malfunctioning CPU just to name a few. You will need to check all these components out and determine if they are still functioning correctly. Screwdrivers and a few other common household tools may be required.
How old is your playstation?
Also try this link if you playstation is outside of waranty
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
I have a Panasonic HDTV and suddenly the colours went double!
hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
Feb 02, 2010 | Panasonic Televison & Video
When I press the PS3 button to start the game, it
try resetting your controller settings, don't load any game into the blue-ray slot, while on the XMB screen press and hold the PS3 button and the settings should appear. after resetting or adjusting your controller settings turn of the ps3 and turn it back on.
Dec 03, 2009 | Sony Little Big Planet
Everything's Gone Green !!!
Try it in someone else's computer.
To see if it is the Monitor or the Video card...
Jul 07, 2009 | LG Flatron L1750S 17" LCD Monitor
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Mxit Problem
i downloaded mxit, set the GPRS several times but still cannot loggin on mxit
Dec 22, 2007 | Motorola Mobility V360 Cellular Phone
Motorola Mobility V360 Cellular Phone Logo
206 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
