Question about Frigidaire GSTR1670A Front Load Washer
The Drum has fallen
The machine was going thru the spin cycle when the machine just started making banging noises. When I emptied the machine, I tried rotating the drum by hand and that's when I noticed that it had dropped. Wha tcan I do
  • 30 Answers
SOURCE: Drum Speed - Unstable
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Posted on Sep 03, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
aborcass
  • 2651 Answers
SOURCE: A loud bang .....like a hammer was thrown in there.
ouch!! can you "lift up " on t he inner drum with a movement of 1 inch or more??? if so sounds as if you needa rear bearing assy. dont know how old machine is, but genearlly if parts not covered its not a worth while repair. will run hundreds of dollars
Posted on Feb 14, 2009
SOURCE: The washer drum is hitting in the spin cycle.
When you take off the back panel, check to see if both shock absorbers are intact. We were having some problems with our (ATF6000E) Frigidaire front-loader recently too. I noticed that one of the shock absorbers was broken, for about $25 I got a replacement (two of them, I couldn't find just one). It took about 15 minutes to replace. No problems. With mine, though, I think because the drum was moving around, it dislodged some wires which made it stop filling up with water after a few seconds. I did a test and it said E5E. I would check to replace your shock absorbers before doing any more laundry so your machine will still work and not have other problems like mine.
Posted on Sep 11, 2009
jmgldsmth
  • 1906 Answers
SOURCE: loose drum bangs during spin cycle turn by hand
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Posted on Jan 25, 2010
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Washing machine makes a loud banging noise during cycle and when I check it the machine has changed position (unit is turned slightly sideways) How to correct
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Regards
Berry
Feb 04, 2010 | Washing Machines
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Hotpoint WF250-Loud banching when spinning
possible broken "spider"support on rear of basket best call serviceif unit is out of warranty be sure to ask for estimate first
May 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Frigidaire GSTR1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
