Question about ITT Night Mariner 160 Monocular
Mariner 160 I'm looking to purchase this set but it has a problem of powering up then shutting back down. Try to power up after that an will not at all after setting for awhile it does the same thing. THANKS Ken
Hello, Yes problem solved.If I shared that input with you, who would I charge your experts or would you continue to profit from me???
Posted on Sep 23, 2008
T43 screen dims and laptop will not shut down
The screen will dim on battery power to save energy. The power settings, found when you right click the power icon in taskbar notification area and go to power options, can be changed to your personal preferences. The shut down issue may be what is running, I can't say what is running, but look at the Start up process in MSCONFIG and shut down what is not necessary at Start UP. Look at tutorials on Faster Start up and Shut down. There may be many items you can shut down/disable to speed up these events. QUESTION: Is this a upgrade to WIN 7 Ultimate, If so your computer me be a bit short on specs, in other words you have reached the computers hardware limits. How much RAM, CPU speed...etc.
Nov 05, 2012 | IBM ThinkPad T30 2366 Notebook
Hitachi P50T501 starts to power up then shuts off
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Aug 25, 2012 | Hitachi P50T501 50 in. Plasma HDTV
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
System Recovery
Hit the Power Button and immediately start hitting the F8 key repeatedly until you see the Safe Mode Options. Select Safe Mode and see if it will boot up. If it does shut down normally and reboot.
Try safe mode again, and this time when it comes up click Start/Accessories/System Tools/System Restore. (If you have windows 7 click Start then type System Restore in the search box and select it when the results are returned). Select a Restore Point (date and time) before you started having problems. Don't worry, System Restore does not delete your data, documents, music, pictures videos or programs (unless the program was installed after the restore point you selected).
System Recovery on the other hand deletes everything and sets your system back to when you first purchased it.
If it happens again on the reboot, get back into safe mode again and see if you can force it to run the check disk utility the next time it starts up. In Safe Mode click Start/Accessories and look for the RUN command. Type cmd and press ok. It will bring up a dos prompt (black screen with white lettering). Type chkdsk /r and press enter. If it says something about drive is locked and it will do it on the next reboot, then select yes.
Read the Manual for System Recovery.
Get online and got to www.google.com In the google search box type: "ASUS Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for System Recovery.
May 16, 2012 | Computers & Internet
Mitsubishi TV, WD 60735; TV shuts off shortly after powering up.
It could be but a couple of other possible reasons---they had problems with this set and its brothers with caps in the main power supply puffing up and causing this "hard to turn on" issue.
A second reason is dust/dirt inside the unit.
All air is coming in via the front of the set and exits the rear--enough dust gets inside and the fans slow down or the lamp gets too hot and set shuts down---don't try this in the house: we take them with back cover off outside the building (on a ramp) and with air clean them out completely--try not to blow it inside the screen. It looks like a dust storm in most cases but can cause exactly the problem you have.
Apr 23, 2012 | Mitsubishi WD-60735 Projection Television
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
I JUST PURCHASED A NEW 19INH AOC MONITOR TO USE WITH MY E-MACHINE. IT WORKS FINE EXCEPT IT SHUTS DOWN WHEN I LEAVE THE COMPUTER AND STAYS THAT WAY UNTIL I MANUALLY START IT AGAIN.
Hello Eldon, don't worry this is a safety devise that is built in to your unit and many others. It gives your screen longer life. GOOD LUCK.
Oct 22, 2011 | AOC 931SWL 19 inch Monitor
After i turn the tv on after a while it just shuts the picture and audio shut down the blue light indicating the power is still on but no audio or video
I have had this problem before and found a loose connection on the power supply module on C310 next to T1 transformer. If you have soldered before you should have on problem. Just take the back off the set and the power module is the one that has the AC cord hookup. Search for C310 and remove the module via screws and unplug it and turn it upside down to the solder side of the board at the C310 location looking for the loose connection there. If you can't see it then solder it anyway and try turning the set back on after putting the board back plugged up and all. Use electronic rosin core solder and a good soldering iron that will get hot enough to do the job. If this is not the problem then suspect an open T3 in the inverter circuit. This is a transformer. T3 may be available by calling Westinghouse by looking on the internet for the manufacturer. Changing it will require using solder wick to remove the transformer and clean the holes to put in a new on. Otherwise if you cannot get T3 the whole board would need to be replaced via manufacturer or try to find on on Ebay doing a search with the model number. Also try Shop Jimmy .com or just a google search
Oct 22, 2011 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Changed batterys no power black eye nothing
How long have you had this ITT Night Mariner 160 NV monocular? Sorry, it needs to taken a part and trouble shoot the electronic components and image intensifier tube. stewbison. If I had my shop set up but I sold all of my electronic test equipment. Contact ITT and ask them what to do. stewbison
May 03, 2011 | ITT Night Mariner 160 Monocular
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
ITT Night Mariner 160 Monocular Logo
194 people viewed this question
Top ITT Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an ITT Optic Expert? Answer questions, earn points and help others
