Question about Asko W640
Wash temperature scale
My Asko W640 suddenly shifted it's wash temperature scale from Celcius to Farenheit. How do I shift it back?
Best Regards
Paul, Norway
  • kakuz Jan 24, 2009
    I have the same problem. please help! :)
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
Posted on Mar 18, 2009
How do i change from farenheit to celcius on the braun thermoscan
1. Make sure the thermometer is turned off.
2. Press and hold down the > button. After about 3 seconds, the display will show this sequence: <<°F>> / <<SET>> / <<°C>> / <<SET>>...
3. Release the > button when the desired scale is shown.
There will be a short beep to confirm the new setting then the thermometer is turned off automatically. When turned on again, the temperature will be shown in the selected scale until the above procedure is repeated.
Feb 20, 2015 | Thermoscan Home
How do I change my luxpro psd111 thermostat to display temperature back to farenheit from Celsius?
On the Luxpro PSD111, Farenheit or Celcius are selected using the Jumper Switch J2 on the rear of the unit's circuit board:
Open = Celcius
Closed = Farenheit
Jan 20, 2014 | Cars & Trucks
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Ultronic clock, humidity & temperature. How does one read the "Temperature Trend" scal on the lower left of the screen. There are three scales shown and the indicators on the scale keeps...
This clock keeps track of the temperatures for each of the last 12 hours. So on the bottom, you'll see the temp at 12 hours ago (-12), 6 hours ago (-6), etc. On the left side, you'll see the temperature in Farenheit go from +5.4 to -5.4 from where it is currently. So if the temperature is 70F degrees right now, and it was 65F degrees 12 hours ago, then it'll show -5 in the first -12 column. It will always be at 0 for the current hour on the right. The scale on the right is in Celcius so it does the exact same thing as Farenheit.
Mar 01, 2011 | Watches
How do I change my A/C temperature from Farenheit to Celcius on my Panasonic remote control?
try to inspect your remote it has a button of adjusting farenheit to celcius or try to see your users manual.
Feb 23, 2011 | Heating & Cooling
Had a "wash motor fault" in July 2007, had a
Welcome to FixYa.
This can be associated with worn brushes in the motor or a sign of a damaged spot on the motor armature, hence when you spun the drum off of the dead/damamged part the unit began to operate.
If capable one can remove the rear panel, and with the aid of a flashlight inspect the brushes and armature.
I'm surprised how often I hear of these motors being replaced when in most cases a new set of brushes will remedy the problem...alas I guess there is more profit for technicians for relatively the same amount of work in replacing a motor.
Let me know if the problem re-occurs or if you'd like a service guide into inspecting the components I alluded to.
Thank you.
Macmarkus :)
Jan 13, 2011 | Asko W640
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Sep 11, 2008 | Asko W640
Workshop manual
type in manuals on your browser bar and a list of sites will come up click on one,type in your details and you should get a pdf file to download your manual, good luck
Jun 05, 2007 | Asko W640
Washing Machines Logo
253 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
