Question about Linksys Wireless-G WRT54G Router
Problems I just got a router to hook up to my computer, but I can't get it to work, I have a internal modem and the directions ask for a external one, I might have the wrong one for my computer, which one is for dial-up
  • 2 more comments
  • BarbaraBrigh Sep 25, 2008
    IMy telephone line goes dirrectly into my computer, I also have a ethernet port, so what do I have to do to get internet yo my laptop.My router is a Broadband Router, I don't have cable or sat. So could I have the wrong router.
  • Kurtis Golub
    Kurtis Golub May 11, 2010
    Is your internet connection dialup or DSL?
  • Jason May 11, 2010
    Just to clarify...you have a "dialup" modem (as in 56k), not DSL, correct?
    If so, the routing functions of your router really won't apply here. However, you may be able to hook your ethernet port on your desktop to one of the LAN (usually numbered 1-4 on the back of the router) ports and then setup the desktop to share its internet connection to the laptop. Keep in mind, it will be slow, but it may work.
  • rich medrano
    rich medrano May 11, 2010
    I'm not sure you have the right equipment or connections.
    The router is not a modem to your computer. Modems are for phone lines and routers are for ethernet connections. So you need to connect the router to the ethernet port on your computer.
    So... with your router I hope there is an ethernet cable that you connect from the router to your computer.
    For trouble shooting... It would be good to know what is feeding the router. A cable modem or DSL modem.
    You should be able to bypass the router for trouble shooting purposes and see if your computer will recognise the internet that way. If so then hook up the modem to the router and the computer to the computer and there should be no change is service.
    I've used several Linksys routers and they all worked fine.
    Problem Solver:
  • 13 Answers
The terms get confusing but we need to know what kind of internet service you use, DSL, Cable, Dial-up? Routers typically work on Hi-Speed DSL or Cable modem networks. There is usually a WAN port and 4+ LAN ports. The WAN is what connects to the cable modem or DSL, and the LAN is where the PC's connect to. Normally everything is plug-n-play but you might have to use an installation disk to configure the wireless access.
HOWEVER if you are using an old, slow, antiquated dial-up modem (some people in rural areas still do!) to get your internet, then using a router for anything other than sharing files between two+ computers is pointless.
Posted on Sep 03, 2009
    Scholar:
  • 62 Answers
I suggest you to get a ADSL router and that will fix your problem. The current one you have purchased is a Broadband router which supports RJ45 Pins and the ADSL supports RJ11 which is what you need.
Posted on May 24, 2009
  • 1,305 Answers
Yes, you've got a "broadband" router... won't help much with dial up..
Posted on May 12, 2009
How do i set up n817 to my home computer for wifi
The computer doesn't control the WiFi, your router/modem do.
Signal comes in through your modem which depending on your provider can have the router built in; it also might have WiFi built in; you can tell by looking at it and see if it has an antenna(s).
There are certain models that don't have external antennas; in that case you would have to call your provider and ask.
If it does, great, you just have to have your device sync to it; if it doesn't, you can ask your provider if you do have the options to get a modem with WiFi or go out a by an external WiFi router and hook it into your network.
Sep 05, 2016 | Cell Phones
What is dsl modem?
Yes it can. The DSL modem is hooked to the phone line or cable and a network cable comes out of it. You hook that cable to the WAN port on the rout
Aug 19, 2014 | NetGear N600 Wireless Dual Band Gigabit...
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
I'm trying to hook up my modem through my router. My last router had an ip address of its own which I used to tell it to work through the router. Does the sb4220?
You may want to have the modem working with your system first and hook up your router after wards.
Disconnect your router and modem.
Reboot your system.
Run your hard wire direct to your SB4220 from computer net card.
Allow to load whatever drivers necessary.
On your computer type ipconfig /all This will show you all your information.
Try the internet and see if it works. If you know the ip of your carrier, Type ping ????? ie: Ping comcast.net
If you recv. a timeout you still have problems.
If you succeed, you are their.
If not, type ipconfig /renew This will reset your ip and configurations.
Now, hook up your router and you should be their.
Oct 08, 2009 | Arris SURFboard SB4220 Modem
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Internet Connection problems
If you want the public IP Address assign to your computer, setup your modem into Bridge then create a broadband dialer to your computer. Through this dialer, you have to type in your username and password which will allow you to connect to the internet.
Jun 09, 2009 | Computers & Internet
Zonet zsr1134we router abruptly stopped working
make sure your modem and your router are not using the same ip address. Many items default to 192.168.1.1. A reset of either device could return it to use this ip address.
No Internet is exactly what you get if your modem is 192.168.1.1 and your router is 192.168.1.1. The problem can happen if either device give out an ip address already used on the network. Change which ever one you can most easily find the documentation on.
I don't recommend using static ip addresses internally, unless your documentation requires it for your setup. changing the set of ip addresses that are distributed by DHCP is the best was around this problem.
Mar 23, 2009 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Loss of internet connection when going through router
Your laptop seems to be hooked to your neighbours unsecured network automatically and it is going online with that. About comcast, when you connect a router to the modem or a computer to the modem, the modem has to be rebooted to give a valid IP to the connected device. If the modem is not rebooted the computer or the router will get 192.168.x.x IP address which is called private IP address.
Nov 19, 2008 | Check Point (CPWSHCRA6500UUS) Router
Linksys wireless problem
hiya krazy327... sorry to hear about your prob.. we,ve all been here at some point!
Can you let me know if it is one specific computer that the problem is with?
If so .. how are you wired to the router "True" wireless or usb/ethernet gateway from the router?
Regards Faggly
Mar 18, 2008 | Linksys Wireless-G Broadband Router
Need to install a modem on a Quick Eagle 4200T CSU
C-NOS:
Basically the modem has to dial in first to give you connection, One end goes to the Phone wall socket and the other end to your computer.
-Now in your case I am sure that your router is a DSL router meaning have no capability of dialing on command from the external modem.
-Nowadays VOIP built in routers are much more capable of dialing numbers directly.
-Old dialing modems should be connected directly from computer to the wall jack (phone lines).
Hope that helped!
Dec 10, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
161 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
