CPQ ACU Can one use CPQ ACU on servers with CPQ 3200 or any controller on other than CPQ motherboards. I can see the disks attached to the 3200 via the OS Disk Admin, but can't get to those drives outside of the OS after CMOS but before the OS.
  • 52 Answers
How to boot from CD
Do you have smart start installed on it? If so:
The F10 "Bios" partition is only available if the server has had SmartStart installed on it. The SmartStart partition is actually a 20Mb (ish) partition on the configured hard disks. If the partition is available, you will be prompted to press F10 at the end of Post boot just before the OS would kick in.
The position of the drives is important so keep them in 0,1,2 & 3. Once you can boot off SmartStart (v5.50 as mentioned), you can reconfigure the Array config in the Array Configuration Utility (ACU).
Jul 30, 2014 | HP Compaq ProLiant ML530 Server
I am not able to load server42003 in intel dg41wv
F2 to get to BIOS. Change the Hard disk Controller to "IDE" from ACHI or RAID.
If necessary, use the Server software raid.
Sep 01, 2012 | INTEL - MOTHERBOARDS Dg41wv Uatx Intel Gma...
Blue light blinking on disk rather than green
the blue light blinking means that the hard drive is being accessed by the ACU (array configuration utility), it can be locally or remote
The light illuminates so that you can identify the disk that you are selecting from the utility.
it does not show any degraded status or possible error
Aug 09, 2010 | HP DL380 G6 (470065153) Server
I want to install a new scsi but when my os windows small business server 2003 it gives me "setup either detected multiple disk in your machine that are indistinguishable or detected raw disk(s). Setup has...
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E"
ACU
Jul 30, 2010 | HP ProLiant ML370 G3 Server
I installed an HP P450 motherboard, pulled from HP D530 SSF Desktop, in a mini-tower case to build a home server, but when I power it up I get an ''HP Invent'' blue screen. The screen has options at the...
That is the BIOS boot screen, it doesn't go beyond that because it can't load the OS. You can disable it if you don't want it but it won't fix your problem - you can't just attach a hard drive with an OS and it will work, it never does and Network Service Boot means that you already have a network server with the appropriate OS for your motherboard. You will have to install the OS on that motherboard on your local disk or, if you still wanna use the Network Service Boot, have an appropriate server on your network that when the PC boots, it sends an extended DHCP request, and your server responds by sending a bootable image to the PC via the network and the PC then boots from this image.
Apr 09, 2010 | HP Compaq d530 SFF PC Desktop
Ibm x series 226 attempt to install os and says no harddrive
Make sure that the motherboard and/or disk controller recognize the drives during POST.
Then check and see if IBM has a server installation CD-ROM that you can use boot the server and automatically load the correct drivers to prep for the OS install. I have downloaded installation CD ISO files from HP and Dell that walked me right through the OS install.
Another important consideration is that servers frequently use disk controllers that are not included in the operating system's driver files.
For example, when installing Windows OS on a RAID controller you must press F6 immediately after the installation CD-ROM starts up.
Later in the installation you will be prompted to insert a 1.44 diskette with the driver for your RAID controller.
The only challenge is to find the correct version of the driver and get it on a diskette.
I hope this helps.
Jul 16, 2009 | IBM xSeries 226 Server
Proliant 5500, installed configuration and OS w2k3 all operationa
What controller do you have? Have you tried running smart start that came with the system?
May 14, 2009 | Compaq ProLiant 5500 Server
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
Computers & Internet Logo
321 people viewed this question
David Payne
David Payne
