Question about Empire ECS HB06M HearthRite Heater
Heater or gas failure ?
I bought a log cabin which has 4 Empire direct vent heaters (DV-210) installed circa 1994. I shut them down in May of this year - pilots out and all. Now I can get a pilot light on 1 heater - but can't get heater to turn on and on the rest of the heaters the pilots won't even come on. Could this be a vapor lock in the line or is there a possibility all the heaters just need work at the same time? The main propane tank was just filled and is at 80% - the rest of the house has appliances running on propane off the main trunk line just like these heaters and they're operating satisfactorily.
  • 4 more comments
  • Bigugly Sep 22, 2008
    Answer is not sufficient - 1) what control panel is Kevin talking about? I'm not aware of any control panel(s) on any of these units. 2) Nothing was changed as I don't screw around with gas at all.
    Hi Sam - the "little copper tube" or what you also referred to as flame sensor - do you mean the thermopile?
    Hi VOTIT - they're heaters for my camp - not a stove to bake a cake in : ) wrong post??
    Hi keemo68 - the heaters are not in series - they do come off a copper branch 6" after entering the house after the regulator. By a branch I mean that the copper line "T"s and goes into opposite directions feeding 2 heaters either way. There is also 1 additional heater (ventless) also off this line and it also will not light - pilot or anything.
    Hi Keemo68 - each heater has its own independent thermostat
  • Bigugly Sep 24, 2008
    Thanks keemo68,I was looking for some confirmation with this issue. I believe the problem is air in the line - had it at another place with a gas fire place (kept it off for the summer and had to bleed line to get firebox ignition but had a pilot without it - tank supply was a considerable distance from ignition source).I'm also getting a new thermopile as I'm told that this is generally a solution.I'll work on it this coming weekend.
  • 2,071 Answers
    President:
  • 1,263 Answers
Can you tell me if the heaters are hooked up in a series or are they independant of each other. this will help pinpoint the problem. also need to know if they each have their own regulator.
Posted on Sep 22, 2008
  • 2 more comments
  • Ronald Mueller
    Ronald Mueller Sep 22, 2008
    you have a pilot on the first heater so it is not vapour locked,however i need to know how the heaters are set up to the main line. are they in a series and have a master regulater and valve with a central thermostat or are they independant of each other?
  • Ronald Mueller
    sir i can help you with this just answer the posed questions i posted
  • Ronald Mueller
    votit it's not an oven it's a heater that runs on propane that link doesn't do anything but waste time
  • Ronald Mueller
    when you light the pilot you have to hold the knob down for at least 2 minutes. this allows the system to purge and hold a primeonce you allow for the time for 2 minutes turn the knob to the on position and the pilot should stay on. if it doesn't then repeat the steps. now if they still won't stay lit then have a qualified HVAC tech check out the valve bodies on each furnace. even though this type of problem no matter how remote it seems can happen. as far as the furnace #1 the reason why it will have a pilot on but won't fire is because the valve body senses a low pressure and therefore won't ingage the thermo ignitor. you have a one way valve in the valve body that has to work properly this valve insures that there is no back pressure with a flame involved this is to keep the tank from exploding.my advice is to have a tech look at the whole system. even though your appliances work at the present time. it's better to be safe than sorry. propane is dangerous. and it's wise to make sure all the bases are covered. keep me posted of the results
    Genius:
  • 1,550 Answers
The little copper tube that sits in the pilot flame may be faulty thats a flame sensor.
Replace this sensor it will solve your problem .
Regarding vapour lock it is not possible for vapour lock that is causing this problem .
Thanks for using fixya
SAM ANDERSON
    Genius:
  • 1,847 Answers
This seem issue with the control panel. did you made any change lately?
Furnace lights right up, but will not shut off with on-off switch or thermastat switch? checked out the thermastat switch and that works fine.
Disconnect the thermostat wires from the gas valve, if unit still runs; you have a short in the gas valve and it needs to be replaced.
Feb 22, 2011 | Empire DV-215 Direct Vent Natural Gas...
My dv-215 direct vent propane unit thermostat is no working right. The burner will not lite until I push down on the mechanism inside the thermostat the burner will shut off when I move the mechanism to...
You need to replace the thermostat if you have to force the contacts to close.
Make sure you get the right type of stat. It appears this is a thermopile millivolt type, as opposed to a standard thermocouple. The stats are not interchangeable.
I noted stats were available at Sears, but there I am sure there are other sources to purchase from.
Dec 18, 2009 | Empire DV-215 Direct Vent Natural Gas...
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
The heater piolet light goes out when you move to use the heater
There is a thermo coupler that shuts the gass off if it is ba. It is locacted just in front of the pilot flame It has to sense the pilot to let the gss through. It is an easy fix and inexpensive.
Nov 12, 2009 | Empire DV-215 Direct Vent Natural Gas...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
B vent configuration of direct vent propane heaters
Yes, the design of the combustion chamber is limited at how much fresh air and combustion air can enter it. If you lengthen the venting, you will be causing more restriction and there will not be enough natural air movement to make it work. It will start, run for a minute or two and poof out. Not to mention you will be circumventing it's UL rating and if you sell your home with it installed, you are liable for any fatality or damage. Do you want to risk that? Don't even think of doing it! There are "Box" heaters out there sized from about 5,000 Btu's on up to 100,000 Btu's. Check the web.
Sep 17, 2008 | Empire DV-215 Direct Vent Natural Gas...
Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Dec 08, 2007 | Empire DV-215 Direct Vent Natural Gas...
Empire ECS HB06M HearthRite Heater Logo
141 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
