Mouse not working
My mouse is not woring and I need some help. I have tried plugging it in in different ports and it is still not working. Can you halp me?
    Problem Solver:
  • 24 Answers
After pluging your mouse and restart your machine.
if its not work replace the mouse.Before replaceing chek your mouse with other computers its working or not?
thanking you
Posted on Sep 28, 2008
My wireless mouse will not work on my laptop can you help me
If you have more than one USB port; try plugging it into
a different port....sometimes a particular port will not recognize
the mouse adapter.
Feb 15, 2016 | Gear Head Gearhead Wireless Optical Mini...
Keyboard works but mouse does not
Richard try plugging mouse into a different port, driver may be corrupt, uninstall,then reinstall driver, try another mouse to see if it will load and usable. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mouse not being detected or working in Windows
My laptop mouse touchpad is not working
How to Fix the Mouse Not Working Problem Windows7
Microsoft Hardware
Oct 31, 2015 | Logitech Computers & Internet
Doesn't laser light appears on the bottom of the mouse. Nothing happens when I hit the "connect" button.
It sounds like these is either a problem with the USB port on the motherboard or with the mouse itself.
Assuming that if a wireless mouse: the batteries are new, the device is actually turned on and the transmitter has been removed from the mouse and plugged into the the USB port and it still does not work, it should be tried on all the other USB ports of the computer. If none work, try on another computer.
This will help determine if the mouse or the computer is the problem. If the mouse does not work on other ports or on the other computer, a defective mouse is likely. If it does work in a different USB port of the original computer, the first USB port is suspect.
If it only works on a different computer, the problem my lie in the setup or BIOS page of the computer. Look for a setting for USB ports. Enable the ports if disabled, and try again. If still no luck, there is some other issue at the motherboard level. Unless fairly new and under warranty, it will probably not be worth trying to fix the problem, when a $20 USB expansion card could be purchased and installed to provide USB connectivity needed.
You could also try connecting a different USB device (if available) to test the USB port. A USB webcam, hard drive, mechanical mouse, etc. are all good choices to test the port. You should indicate or cover any ports that are found to be defective.
I hope this helped and good luck!
Nov 01, 2010 | Computers & Internet
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
Jul 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
After rebooting my cpu my mouse stopped working. My cpu does not recognize my mouse? The mouse works because i tried it on a different cpu. what can be causing this?
Did you try to reboot?
Do you have an optical mouse? (if yes: is the red light on?
(Then the mouse is recognized and you must configure your mouse options)
Did you try to connect your USB mouse to another connector?
Or if PS2 connector: Turn of the pc and connect the mouse and power on.
Did you install a new driver? (then uninstall this driver)
Try looking for the most recent mouse driver on the manufacturer site.
Jul 13, 2009 | HP Pavilion a1610n PC Desktop
When working on my computer Optiplex 745 Windows XP professional the optical mouse becomes non operative (no response, no red light). If I shut down and restart the computer it is fine.
Make sure the HDD jumper is set to master and see whether it helps.
If not the HDD is not recognised by the PC. Also make sure the connections between the HDD and mother board.
· Try a different IDE cable
· Try a different HDD an
All the best!
Jul 06, 2009 | Dell U0636 Mouse
Technika optical wireless mouse not working
Make sure the mouse is linking to the wireless receiver on you have plugged into the computer (there should be a reset button on the mouse to establish a new link).
May 13, 2009 | Casio Parts Cash Register PC Desktop
Mouse wont work
Try a different USB port
Hope i could help
Comment if you need more assistance
Apr 28, 2009 | UltraLast FOR TOSHIBA SATELLITE A50/55...
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
