Problems with the steame that is leaking. Can I repair myself? If yes, how. Or is it going to cost me a lot if a go on St-Laurent in montreal to get my machine repaired? I'm 45 away from there.
I saw you provided a solution to the same problem...
thank you,
René rdestrempes@gmail.com
-   Hi, I was wondering if you know where i can get instructions to disassemble my odea go. Smoke and an electrical burning smell were coming out of the back as i used the steamer. I need to know how to remove the steamer pipe so that i can get inside to have a look at how bad the damage was
You have to open the top of the machine, then you have to take of the left side on the machine.
Now you will see the steam valve in the left corner, loosen the screw and take off the little printed circuit card, then you have two more screw to loosen. Take off the steam valve and in the edge you have a clip, loosen this and the one in the top where the pin is, take out the little pin in the steam valve and you will see the two gasket you have to replace.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
nespresso not piercing capsules ? Any ideas its this model...
(More)
nespresso not piercing capsules ? Any ideas its this model http://www.seriouseats.com/images/20091021-nespresso.jpg
