Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hyundai my engine light is on and my fan does not work who can i find out what is the fuse for my fan ?
  • 177 Answers
Read your owners manual
Posted on Sep 23, 2008
Relay fuse on a 2006 hyundai elantra
The relay will be marked fan low and fan high.
Jan 16, 2018 | Hyundai Cars & Trucks
Changed coolant fan still not working
Quit throwing money away at good parts. It's not the sensor. Have the codes read. Auto parts stores will read them for free. Check fuses..
Mar 05, 2016 | 2008 Hyundai Sonata
2000 hyundai elantra has a blown fuse. 20A con. What is the fuse for. Can't fill my gas tank keep stopping.
The fuel filling problem is usually a bad charcoal canister. They get saturated and are not able to breathe properly. ( ruined when people top off there tank) It could be other things maybe a stuck vent valve but that should set a check engine light. As far as the fuse goes, replace it with the correct amperage fuse. If it blows again that circuit will need to be checked for short or over load. (Possible someone added aftermarket device to circuit drawing the circuit over the 20 amps its designed for.)
May 30, 2015 | 2000 Hyundai Elantra
Engine cooling fans will not turn on/2001 hyundai tiburon
Sensor on rad is gone, easy fix. Look for a unit on rad with wires going into it, this is the problem.
Apr 05, 2013 | 2001 Hyundai Tiburon
Where is the radiator cooling fan relay on a 2006 Sonata 3.3L?
The relay in engine compartment fuse box.
For its exact location and wiring diagram,click the link below:----Hyundai Sonata cooling fan not working
---------------This will help.Thanks.
Feb 26, 2012 | 2006 Hyundai Sonata
Interiour light dosent work *** lighter dosent work
First thing to check: fuse(s) for the cigarette lighter/power port, which may also be the same fuse for the interior lighting that went out. Could post the location of your fuse box (most Hyundai cars have 2 - one under hood, and a second under the dash (where your power port/interior lighting fuses are most likely located)), if you could clarify which model/year/engine size Hyundai car/truck is giving you problems.
Jun 09, 2011 | Hyundai Accent Cars & Trucks
My hyundai verna"s engine cooling fan is not working. i need to find out how it is corrected & how much it costs?
Before pay someone to fix the problem, make sure that:
Fan blades are tight with motor shaft.
Fan blades are not jammed.
The fan motor is O.K.
The fan fuse is O.K.
There is no temperature sensor code.
This will narrow the diagnosis. Hope will help.
Oct 08, 2010 | Hyundai Accent Cars & Trucks
Blower fan not working - Hyundai 2004 Santa Fe
Try a SHOCK test to the blower motor case. What I mean is SHOCK the case by hitting it with the palm of your hand (make sure you have the blower switch 'HIGH' and the IGN key also 'ON'.. if the blower starts working, you have an intermittent contact in the motor itself. If this doesn't work, get a test light and connect it to the connector that plugs into to the blower motor - if the test light illuminates, then the problem is obviously in the motor. If it doesn't, then you have a wiring/switch/power supply problem.
May 21, 2009 | 2004 Hyundai Santa Fe
Wants to overheat even when fans come on
it sounds like your fans are not working. you should check your owners manual and locate the fuse for the engine fan and check it. now if the fuse is good Bring the car to your local repair shop and have this problem checked out. asap
Apr 21, 2009 | Hyundai Motor 2004 Sonata
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
