Question about RCA DRC8335
Power supply burnt
Q101 and R106 were burnt up. I found the Q101 mosfet, but can't determine the value of R106. The colors are burnt off and the value keeps changing as I clean it more. I also need the values of R103A and R108A. Any chance of getting a cheap schematic? Thanks for any info.
  • rcafixer Oct 02, 2008
    Thanks a lot lesfix; I'll let you know if this fix will correct the problem.
  • Mike Adams
    Mike Adams May 11, 2010
    LesFix. Regarding resistor R106 rating, note the color code (green-black-gold-silver) specifies a 5 ohm resistor 10% tolerence, not 1/2 ohm.
R106 is a .5 ohm. It is green,black,gold, and silver. I believe it is a 1/2 watt resister
R103A is a 27 ohm and R108A is a 470 ohm resister.I have no schematic.
Posted on Oct 02, 2008
  • lesfix Feb 19, 2009
    rcafixer,Mike Adams,and others, my mistake it is a 5 ohm and not a 1/2 ohm resistor.
I have found power card of Del In1930f defective, after further checking I have found mosfet A2764 burnt and 1NN801B ic of driving card burnt, please help how to fix this problem.
It is considered unsafe to attempt a repair of a power supply of that design. It will probably cost less, than the parts and expertise, to replace it.
Dec 17, 2016 | Computers & Internet
Does anyone have the schematic of the RM1-4815 which is the low-voltage supplier board. Actually I just want to know the value of the R106. It has burned in my board. Thanks a lot
You would be better suited to order a new power supply board such as the one listed below on eBay, as HP does not provide any real support for things such as this and it is probably /maybe a lot cheaper anyhow doing it this way! I know it seems like a waste of money for 1 stinkin' cheap resistor (if that's all it is) but what if the other part it is attached to that caused the burn out is nearly bad also?
NEW HP Color LaserJet CP1215 CP1515n CP1518ni LV Power Supply RM1 4815...
Good Luck!
Rich Lilja
Aug 21, 2015 | HP LaserJet CP1215 Color Printer
No picture - no green light. Is there an external fuse somewhere ?
hi...yes there is a fuse found at the back. if you can dismantle the back cover and look for the power supply's full of big/small capacitor , power mosfet, that area look for a cylindrical glass. the hair like wire visible inside it check if it split apart or if it already burn/ darkih color it's busted...don't you worry because its replaceable...replace only w/ same type and value...good day..pls. rate and vote...
Feb 17, 2011 | LG 37LC7D 37 in. LCD HDTV
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
HI I have a FSP200-61GT SPI switching power supply with a burned out Mosfet on the high voltage side. There is a (I think)a .5 or 1 watt resistor on both sides of the mosfet. But they test good, my problem...
Please give motr of the devices fixed on same heat sink. Search for SMPS IC like FPS or similar, search their application notes and the datasheet of the nMOS. then you can get idea. without those data Solution is impossible.
Jan 27, 2010 | HP and Compaq Pavilion Replacement 200w...
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
Jan 07, 2010 | Computers & Internet
Mosfet in my asus motherboard burnt out,
Better to have the motherboard replace, do not wait until some other components might be also damage. Commonly mosfet is use in power supplies regulator. It can kill your processor and memory.
And also check your power supply. It might also having problems.
May 02, 2009 | ASUS P4GE-MX Motherboard
Part no. for a Transistor 27611 637205
I was looking for the same part and discovered that it is an AP2761I (capital i not one at the end). Documentation on it can be found at
I haven't yet found a supplier as, in this Dell E153FPf 15" LCD monitor, neighbouring components R856, C856 and R861 are so burnt out that I don't know what values to replace them with. If in return you could tell me the values of components near your AP2761i-A, I would appreciate it.
Mar 28, 2009 | HP Vs17 17" LCD Flat Panel Monitor
MA2 laptop, not charging battery, changed burnt 4407 chip, no LED now.
This unit had a RED CHARGE error. Replaced PQ38 solved the problem.
If you get an error on the charge circuit after replacing the PQ38 you should also replace PQ38 because it too may be blown. Make sure Pin 1 where the dots. Also check the MOSFET on the other side of the COIL too.
Oct 08, 2008 | Gateway MX6030 Notebook
Durabrand DBDVR01 dvd/video recorder combi
durabrand model dbdvr01 power supply problem. r106 open circuit,q101 short circuit,d102 short circuit,ic101 blown up,suspect r108a and r100a faulty. ROY
Apr 25, 2008 | Televison & Video
RCA DRC8335 Logo
261 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
