Question about Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television
Wt-42313 Hi, Our tv doesn't turn on. I checked the circuit breaker and it's fine. It acts as is there is no power. The dvd player is plugged into the same outlet and works fine. My wife heard a pop 15 minutes earlier and didn't know what it was. Is there a fuse?
  • simscy Sep 22, 2008
    Thankyou, I will pull the back off this evening and report back.
    New Friend:
  • 74 Answers
There probably is a fuse blown. but something made the fuse blow. If you can take the back off and find out if one did blow and the location for it i can probably help you further.
Posted on Sep 22, 2008
WT-42313 - Won't turn on. TV gives and error code of 24. I found that this is an issue with vertical deflection. I need to know how to repair this issue.
Ck pico fuse F9A05 5amps it will be green or yellow looks like resistor if bad, replace Both STK ICs STK394-250 and 2 resistors R8c13 &14 3.9ohms also resolder all 3 yoke plugins on board.
Sep 20, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Wt-42313 wont turn on
first you can email me direct-etower.766@netzero.net--2 and then 3 blinks is deflection circuit problem---what was wrong with set to begin with?
Sep 07, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power on 2 sec. then off won't turn mitsubishi wt-42313
with this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Jun 17, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi wt-42313 switching tv format problems
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 23, 2017 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 TV
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Sep 01, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Turning on my tv set
Same issue - our successful fix, at least temporarily, is to unplug power cable from outlet for at LEAST 4 hours...pref. overnight.
Jul 15, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
